Home » Modeling » EMF » generated editor
generated editor [message #415751] Fri, 04 January 2008 14:39 Go to next message
When I generate and editor plugin I get a context menu to add a new child.
This I think only happens when the relation is by containment.
If it is not I can change the genmodel and specifically ask for certain
features to be children. I then get the context menu to add a new child but
then it is not in the resource and fails when I try to save the objects.
The other thing I'm wondering is when I use the wizard it creates an
instance model with the EClass I specify. However after that there is no way
to add another object at the root of my resource. Is there a special flag in
the genmodel to enable that?
Jean-Claude
Re: generated editor [message #415752 is a reply to message #415751] Fri, 04 January 2008 14:51 Go to previous message
Jean-Claude,
Comments below.
jc wrote:
It happens for any feature for which the GenFeature's child creation
property is true. By default it's set to true only for containment
references.
Yep. You'd need to specialize the code (like the create child command
itself) to consider where the new object will be contained in order to
be persisted correctly. You might for example add the new child to the
root of the same resource as the parent to to which you are adding it.
Or you might have some other containment feature that acts as a good
container.
No, we never provided support for that. A resource is generally allowed
to hold any number of any type of EObject so obviously a menu item that
lets you choose from thousands of different choices wouldn't be
usable. At this point, you'd need to specialize your resource's item
providers to support things like child creation...
> Thanks
> Jean-Claude
Previous Topic:[Announce] XMF
Next Topic:Import from Annotated Java into a different project
Current Time: Mon Oct 27 08:54:05 EDT 2025
Powered by FUDForum. Page generated in 0.04745 seconds
