Home » Modeling » EMF » Option for public constructor
Option for public constructor [message #408858] Thu, 26 April 2007 20:58 Go to next message
Is there an option to set in the genmodel so that the generated constructors
are public instead of protected?
Pradeep
Re: Option for public constructor [message #408860 is a reply to message #408858] Fri, 27 April 2007 06:33 Go to previous messageGo to next message
Pradeep,
No. But I suppose adding that would be quite trivial to support.
It's also possible to copy the template, modify it to be public, and use
dynamic templates to generate what you want. I wonder why you would
want it public?
> Thanks
> Pradeep
Re: Option for public constructor [message #408865 is a reply to message #408860] Fri, 27 April 2007 11:11 Go to previous messageGo to next message
Well, I am writing a library for others to use. As I update the existing
code using EMF, i don't want any previous code that uses this library, which
often uses the public constructor, to break. Also I want to provide a most
familiar way of creating objects.
Pradeep
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f0sjhe$q9p$2@build.eclipse.org...
> Pradeep,
> No. But I suppose adding that would be quite trivial to support. It's
> dynamic templates to generate what you want. I wonder why you would want
> it public?
>> constructors are public instead of protected?
>> Thanks
>> Pradeep
Re: Option for public constructor [message #408869 is a reply to message #408865] Fri, 27 April 2007 12:32 Go to previous message
--------------060906050006070901030106
Pradeep,
It's certainly trivial to add such an option to the generator, so open a
bugzilla feature request and we'll consider it.
> Thanks
> Pradeep
>> Pradeep,
>> it public?
>>> Thanks
>>> Pradeep
<html>
<head>
</head>
Pradeep,<br>
<br>
a bugzilla feature request and we'll consider it.<br>
<br>
<br>
Pradeep wrote:
<blockquote cite="midf0t3qi$9at$1@build.eclipse.org" type="cite">
<pre wrap="">Well, I am writing a library for others to use. As I update the existing
Pradeep
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:f0sjhe$q9p$2@build.eclipse.org">news:f0sjhe$q9p$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Pradeep,
it public?
Pradeep wrote:
</pre>
<pre wrap="">Is there an option to set in the genmodel so that the generated
Pradeep
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------060906050006070901030106--
Previous Topic:[Transaction] How to do thread safe transaction demarcation
Next Topic:Overriding XMLString in XMLSaveImpl
Current Time: Sun Oct 19 00:07:16 EDT 2025
Powered by FUDForum. Page generated in 0.04214 seconds
