Home » Archived » BIRT » Two question about javascript in birt
Two question about javascript in birt [message #368828] Mon, 29 June 2009 16:21 Go to next message
I have two questions about javascript in birt.
First, can I make a global javascript function that can be reused by many
reports?
Second, is there an XML parser in BIRT javascript?
Thank you very much.
Larry
Re: Two question about javascript in birt [message #368831 is a reply to message #368828] Mon, 29 June 2009 17:37 Go to previous messageGo to next message
Originally posted by: jasonweathersby.windstream.net
Larry,
If you want to reuse a global JavaScript function you have basically two
choices. 1 - put it in a .js file in your resource folder and include
it in every report. 2 - Create a plugin that implement script function
extension. This is pretty simple and it has the side effect of making
the function appear the expression builder. See this post:
http://birtworld.blogspot.com/2008/09/birt-231-adding-functi ons-to-expression.html
Jason
Larry Li wrote:
> Hello,
> many reports?
> Larry
Re: Two question about javascript in birt [message #368832 is a reply to message #368828] Mon, 29 June 2009 17:39 Go to previous messageGo to next message
You can also call Java to parse the xml like:
importPackage( Packages.javax.xml.parsers);
importPackage( Packages.org.xml.sax);
importPackage( Packages.org.w3c.dom);
importPackage( Packages.java.io);
function getTagValue(file, tagName) {
factory = DocumentBuilderFactory.newInstance();
builder = factory.newDocumentBuilder();
document = builder.parse( new InputSource( new FileInputStream( file ))
nlist = document.getElementsByTagName(tagName);
return nlist.item(0).getFirstChild().getNodeValue();
mydatavalue = getTagValue("c:/test/parms.xml", "parm1");
Jason
Larry Li wrote:
> Hello,
> many reports?
> Larry
Re: Two question about javascript in birt [message #368833 is a reply to message #368832] Mon, 29 June 2009 17:56 Go to previous messageGo to next message
This is great!
Thanks a lot for replying.
Larry
> Jason
> Larry Li wrote:
>> Hello,
>> many reports?
>> Larry
Re: Two question about javascript in birt [message #368844 is a reply to message #368831] Tue, 30 June 2009 14:12 Go to previous messageGo to next message
Jason,
I exported the plugin project to a .jar file.
Where do I put this jar file? for both my eclipse environment and birt
server (i.e. WebViewerExample).
Thanks.
LArry
> Larry,
> Jason
> Larry Li wrote:
>> Hello,
>> many reports?
>> Larry
Re: Two question about javascript in birt [message #368845 is a reply to message #368844] Tue, 30 June 2009 14:24 Go to previous messageGo to next message
Larry Li wrote:
> Jason,
> Thanks.
> LArry
I also got this error when I exported the plugin project:
JAR creation failed. See details for additional information.
Resource is out of sync with the file system: '/plugin/plugin.xml'.
plugin/META-INF/MANIFEST.MF was replaced by the generated MANIFEST.MF
and is no longer in the JAR.
Exported with compile warnings:
plugin/src/plugin/actions/KashrusFuncExecutor.java
This is my plugin.xml
<?eclipse version="3.4"?>
<plugin>
<extension
id="MyScriptFunctions"
name="MyScriptFuncitons"
point="org.eclipse.birt.core.ScriptFunctionService">
<Category
factoryclass="plugin.actions.KashrusFuncFactory"
name="KashrusFuncExecutor">
<Function
name="TestFunction">
<DataType
value="String">
</DataType>
<Argument
name="source">
<DataType
value="String">
</DataType>
</Argument>
</Function>
</Category>
</extension>
</plugin>
Re: Two question about javascript in birt [message #368847 is a reply to message #368845] Tue, 30 June 2009 14:40 Go to previous messageGo to next message
Larry,
For design time should be in your eclipse/plugins directory.
for all in one it will be in this dir.
birt-report-designer-all-in-one-verion\eclipse\plugins
on the WebViewerExample put it in:
WebViewerExample/WEB-INF/platform/plugins
Jason
Larry Li wrote:
> Larry Li wrote:
>> Jason,
>> Thanks.
>> LArry
> <plugin>
> <extension
> <Category
> <Function
> <DataType
> value="String">
> </DataType>
> <Argument
> name="source">
> <DataType
> value="String">
> </DataType>
> </Argument>
> </Function>
> </Category>
> </extension>
> </plugin>
Re: Two question about javascript in birt [message #368849 is a reply to message #368847] Tue, 30 June 2009 15:24 Go to previous messageGo to next message
This does not work. This is what I do:
1. Create a plugin project, testplugin.
2. copy these files (from the zip file provided in your link) to
testplugin:
/jslibs
/META-INF
/src
build.properties
plugin.xml
3. Eclipse says there is error in MyCategory.execute
It says the method needs one more argument, so it becomes this:
execute(Object[] args, IScriptFunctionContext arg1)
4. I export the project to a jar file, and put this jar to eclipse/plugins
But I still cannot see MyCategory.TestFunction in Report Design.
Is anything wrong or I miss anything?
Thanks.
Larry
> Larry,
> birt-report-designer-all-in-one-verioneclipseplugins
> Jason
> Larry Li wrote:
>> Larry Li wrote:
>>> Jason,
>>> Thanks.
>>> LArry
>> <?xml version="1.0" encoding="UTF-8"?>
>> <plugin>
>> <extension
>> <Category
>> <Function
>> <DataType
>> value="String">
>> </DataType>
>> <Argument
>> name="source">
>> <DataType
>> value="String">
>> </DataType>
>> </Argument>
>> </Function>
>> </Category>
>> </extension>
>> </plugin>
Re: Two question about javascript in birt [message #368857 is a reply to message #368849] Wed, 01 July 2009 09:46 Go to previous messageGo to next message
Larry,
Sorry for asking the obvious but are you looking in the expression builder?
Jason
> testplugin:
> /jslibs
> /META-INF
> /src
> build.properties
> plugin.xml
> Thanks.
> Larry
>> Larry,
>> Jason
>> Larry Li wrote:
>>> Larry Li wrote:
>>>> Jason,
>>>> birt server (i.e. WebViewerExample).
>>>> Thanks.
>>>> LArry
>>> MANIFEST.MF and is no longer in the JAR.
>>> <plugin>
>>> <extension
>>> <Category
>>> <Function
>>> <DataType
>>> value="String">
>>> </DataType>
>>> <Argument
>>> name="source">
>>> <DataType
>>> value="String">
>>> </DataType>
>>> </Argument>
>>> </Function>
>>> </Category>
>>> </extension>
>>> </plugin>
Re: Two question about javascript in birt [message #368859 is a reply to message #368857] Wed, 01 July 2009 10:08 Go to previous messageGo to next message
Larry,
It looks like the script context was added after I wrote the blog. Here
is the updated MyCategory file. Also in the expression builder look at
Birt Functions and MyCategory should show up underneath.
Jason
package my.expression.functions;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.script.functionservice.IScriptFunction Context;
import org.eclipse.birt.core.script.functionservice.IScriptFunction Executor;
* String functions.
class MyCategory implements IScriptFunctionExecutor
private static final long serialVersionUID = 1L;
private IScriptFunctionExecutor executor;
MyCategory( String functionName ) throws BirtException
if ( "TestFunction".equals( functionName ) )
this.executor = new TestFunction( );
else
throw new BirtException( "my.expression.funcitons",
null,
"invalid.function.name" + "MyCategory." + functionName );
private class TestFunction implements IScriptFunctionExecutor
public Object execute( Object[] args, IScriptFunctionContext arg1)
if ( args == null || args.length != 1 )
throw new IllegalArgumentException( "The number of arguement is
incorrect." );
if( args[0] == null){
return null;
}else{
StringBuffer sb = new StringBuffer( (String)args[0]);
return sb.reverse().toString();
public Object execute( Object[] arguments, IScriptFunctionContext arg1
return this.executor.execute( arguments, arg1 );
Jason Weathersby wrote:
> Larry,
> Jason
>> testplugin:
>> /jslibs
>> /META-INF
>> /src
>> build.properties
>> plugin.xml
>> eclipse/plugins
>> Thanks.
>> Larry
>>> Larry,
>>> Jason
>>> Larry Li wrote:
>>>> Larry Li wrote:
>>>>> Jason,
>>>>> Thanks.
>>>>> LArry
>>>> <plugin>
>>>> <extension
>>>> <Category
>>>> <Function
>>>> <DataType
>>>> value="String">
>>>> </DataType>
>>>> <Argument
>>>> name="source">
>>>> <DataType
>>>> value="String">
>>>> </DataType>
>>>> </Argument>
>>>> </Function>
>>>> </Category>
>>>> </extension>
>>>> </plugin>
Re: Two question about javascript in birt [message #368885 is a reply to message #368859] Thu, 02 July 2009 12:00 Go to previous messageGo to next message
Jason,
I made it! Thanks a lot.
My mistake was that I export the project by using: Export --> Java --> JAR
file.
Actually, it has to be exported to a "Deployable plug-ins and fragments."
Then it works.
Larry
Re: Two question about javascript in birt [message #368890 is a reply to message #368885] Thu, 02 July 2009 15:19 Go to previous messageGo to next message
Do you mind adding a comment to the blog entry for clarification for
future users?
Jason
Larry Li wrote:
> Jason,
> JAR file.
> Then it works.
> Larry
Re: Two question about javascript in birt [message #368910 is a reply to message #368890] Mon, 06 July 2009 10:15 Go to previous messageGo to next message
Sure!
But where and how do I add it?
Larry
> future users?
> Thanks
> Jason
> Larry Li wrote:
>> Jason,
>> JAR file.
>> Then it works.
>> Larry
Re: Two question about javascript in birt [message #368911 is a reply to message #368910] Mon, 06 July 2009 10:22 Go to previous message
Forget about this. I added the comment.
> Sure!
> Larry
>> future users?
>> Thanks
>> Jason
Previous Topic:row minimum height in ppt
Next Topic:Integrating BIRT into RAP applications
Current Time: Thu Nov 06 14:10:58 EST 2025
Powered by FUDForum. Page generated in 0.06863 seconds
