Home » Eclipse Projects » Equinox » Importing existing Bundles
Importing existing Bundles [message #33348] Wed, 14 January 2004 19:27 Go to next message
What's the best way to import the code for an existing OSGi bundle into
Eclipse so that it can be dynamically included in other plugin/bundles'
dependencies? The bundle already has a BundleActivator. I've tried
creating a new Plugin, importing the source code, then converting the
whole thing to an OSGi bundle. It seems to work, but I'm sure that's the
best approach.
Stephen
Re: Importing existing Bundles [message #33383 is a reply to message #33348] Wed, 14 January 2004 20:35 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
You should just be able to run it as per normal. The "detail" is how to get
the darn thing installed. Two real choices
1) install using the console
2) insert a
"Stephen Goldbaum" <stephen.goldbaum@lehman.com> wrote in message
news:bu4mqc$3ek$1@eclipse.org...
> best approach.
> Stephen
Re: Importing existing Bundles [message #33421 is a reply to message #33383] Wed, 14 January 2004 20:36 Go to previous messageGo to next message
"Jeff McAffer" <jeff_mcaffer_REMOVE@ca.ibm.com> wrote in message
news:bu4qoi$78c$1@eclipse.org...
get
> 2) insert a
the
> > best approach.
> > Thanks,
> > Stephen
Re: Importing existing Bundles [message #33474 is a reply to message #33421] Wed, 14 January 2004 20:47 Go to previous messageGo to next message
Unbelievable!! I accidentally posted twice within 10 seconds. Sorry about
that. Now to continue...
1) install using the console. In the current code there are some bugs which
likely prevent you from installing the bundle as a jar (this is being worked
on and should be available very soon). You can just extract the bundle into
a dir and install that dir. So something like
osgi> install reference:file:<path to the exploded bundle>
should do it.
2) insert a plugin.xml in there and use the Eclipse update mechanisms (e.g.,
just drop it in the plugins dir) Note taht I am not sure the the
plugin.xml is really even needed. The update guys were in the process of
making update understand manifest.mfs but I'm not sure that that code has
been released.
The expectation is that existing OSGi bundles will just work. This scenario
is currently not heavily tested but we believe it is important for 3.0.
Your help in fleshing this out would be greatly appreciated. Ask questions
and push for the function/scenarios you need. Detailed bug reports are
highly prized. We want to make this the best we can in the time left so
every bit helps.
Jeff
into
plugin/bundles'
> the
> > > best approach.
> > > Thanks,
> > > Stephen
Re: Importing existing Bundles [message #33508 is a reply to message #33421] Wed, 14 January 2004 20:53 Go to previous messageGo to next message
Hmm... keeping me guessing, eh? Actually, I haven't figured out how to
start the initial eclipse workspace with the console. I've tried running
"eclipse -console" from cmd (windows xp) but that seems to use javaw, so
there's no console. Either way, I'd really like to import the bundle into
its own project so I can continue to develop it.
Stephen
> get
> > 2) insert a
> the
> > > best approach.
> > > Thanks,
> > > Stephen
Re: Importing existing Bundles [message #33712 is a reply to message #33508] Thu, 15 January 2004 23:36 Go to previous messageGo to next message
The eclipse.exe has not been updated to know about -console (and to then use
java.exe). Two options:
eclipse.exe -console -consolelog
or
eclipse.exe -console -vm <path to java.exe>
Jeff
news:bu4rr4$879$1@eclipse.org...
> Stephen
to
> > get
> > > 2) insert a
into
plugin/bundles'
the
that's
> > the
> > > > best approach.
> > > > Thanks,
> > > > Stephen
Re: Importing existing Bundles [message #33912 is a reply to message #33712] Fri, 16 January 2004 10:31 Go to previous message
Thanks. That did the trick.
> or
> Jeff
> > Thanks,
> > Stephen
> to
> > > get
> > > > 2) insert a
> into
> plugin/bundles'
> the
> that's
> > > the
> > > > > best approach.
> > > > > Thanks,
> > > > > Stephen
Previous Topic:When is a plugin a dependency of another...
Next Topic:ClassLoading/Security issue
Current Time: Wed Oct 29 12:22:07 EDT 2025
Powered by FUDForum. Page generated in 0.04084 seconds
