Home » Eclipse Projects » Eclipse Platform » [JFace/Actions] Radio button style actions problem
[JFace/Actions] Radio button style actions problem [message #312875] Thu, 22 February 2007 10:38 Go to next message
Originally posted by: dc.schneid.googlemail.com
I have the following little problem with a set of radio-button-style
actions:
I want to trigger action A when action B finishes automatically, so that the
button of A is pushed and that of B is no longer pushed. Calling A's run
method doesn't change the button state. Calling setChecked(true) on A won't
change B's button state; I end up with two pushed buttons although the
styles are radiobutton!
Do I really have to uncheck B manually, check A manually and call A's run
method? Is there a more elegant way to it?
Put differently: Can I get the platform to display a radiobutton style
behaviour also when the actions are triggered by the program?
BTW, the context is that of a diagram editor. A ist the "Select" tool, B is
a shape drawing tool and I want to program to go back to the select tool
once the user has drawn the shape.
David
Re: [JFace/Actions] Radio button style actions problem [message #312881 is a reply to message #312875] Thu, 22 February 2007 13:10 Go to previous message
SWT will check/uncheck radio buttons if they are sibling controls right
next to each other. What style are the Actions that you are instantiating?
PW
Previous Topic:Relaunching Application
Next Topic:[Requesting Support]Eclipse + knopflerfish
Current Time: Mon Oct 20 13:36:29 EDT 2025
Powered by FUDForum. Page generated in 0.03837 seconds
