| Re: Virgo Tooling M4 Released [message #871257 is a reply to message #870817] |
Fri, 11 May 2012 12:37   |
Great news! Glad to see support in this area as I've depended upon this heavily in the past. I have been looking forward to working with Virgo 3.5 but dreaded the idea of it without Eclipse IDE support. With that said, and my apologies if this isn't the right forum, I tried the basics of creating a server environment from scratch and ran into problems. I cannot seem to create a server configuration at all.
This is with Eclipse 3.7.2 (downloaded today), the Virgo Tooling support just released, Mac OSX 10.7.4, Java 1.0.6_31, and Virgo 3.6M4.
1) Opened Virgo perspective
2) Clicked on new server wizard...
3) Selected EclipseRT | Virgo Runtime
4) Clicking Add... at this point does nothing.
5) Clicking Configure runtime environments... opens a dialog. I can Add... and Remove, however I cannot Edit... - nothing happens.
Also, when I open Preferences and select Virgo | Repository Browser I get an error dialog.
In the Eclipse IDE log I do see the following a number of times, which seems to correlate to my attempts to edit a runtime environment and open the preference page:
at org.eclipse.virgo.ide.runtime.core.ServerUtils.createDependencyLocator(ServerUtils.java:171)
at org.eclipse.virgo.ide.runtime.core.ServerUtils.createDependencyLocator(ServerUtils.java:159)
at org.eclipse.virgo.ide.runtime.internal.ui.projects.ServerProject.isRuntimeExists(ServerProject.java:137)
at org.eclipse.virgo.ide.runtime.internal.ui.projects.ServerProject.updateWorkspaceProject(ServerProject.java:186)
at org.eclipse.virgo.ide.runtime.internal.ui.projects.ServerProject.<init>(ServerProject.java:69)
at org.eclipse.virgo.ide.runtime.internal.ui.projects.ServerProjectManager.getProject(ServerProjectManager.java:61)
at org.eclipse.virgo.ide.runtime.internal.ui.projects.ServerProjectManager.updateProjects(ServerProjectManager.java:81)
at org.eclipse.virgo.ide.runtime.internal.ui.ServerUiPlugin.start(ServerUiPlugin.java:84)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
... 113 more
| Re: Virgo Tooling M4 Released [message #881371 is a reply to message #871257] |
Mon, 04 June 2012 08:28  |
I have downloaded the latest STS and Eclipse this week-end and I got the same error when I installed the tooling from the milestone repository. Then I installed the snapshot version and that worked.
FUDForum. Page generated in 0.39372 seconds
