Home » Eclipse Projects » Standard Widget Toolkit (SWT) » osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError
osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #488277] Sun, 27 September 2009 06:41 Go to next message
I keep getting this error under (Topic).
Any Hints? (If this is the right place to ask?)
Greetings,
Ralf
P.S. Java 6 under Snow Leopard runs fine (in contrast).
java version "1.6.0_15"
Java(TM) SE Runtime Environment (build 1.6.0_15-b03-226)
Java HotSpot(TM) 64-Bit Server VM (build 14.1-b02-92, mixed mode)
java.lang.NoClassDefFoundError: Could not initialize class
com.ibm.icu.impl.JavaTimeZone
at com.ibm.icu.util.TimeZone.getDefault(TimeZone.java:804)
at com.ibm.icu.util.Calendar.getInstanceInternal(Calendar.java: 1630)
at com.ibm.icu.util.Calendar.getInstance(Calendar.java:1594)
at
com.ibm.icu.text.SimpleDateFormat.initialize(SimpleDateForma t.java:465)
at
com.ibm.icu.text.SimpleDateFormat.<init>(SimpleDateFormat.java:435)
at
com.ibm.icu.text.SimpleDateFormat.<init>(SimpleDateFormat.java:368)
at
org.eclipse.ui.internal.views.log.LogSession.setDate(LogSess ion.java:43)
at
org.eclipse.ui.internal.views.log.LogSession.processLogLine( LogSession.java:67)
at
org.eclipse.ui.internal.views.log.LogReader.parseLogFile(Log Reader.java:90)
at
org.eclipse.ui.internal.views.log.LogView.readLogFile(LogVie w.java:814)
at
org.eclipse.ui.internal.views.log.LogView.createPartControl( LogView.java:172)
at
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:367)
at
org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:226)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at
org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2229)
at
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1067)
at
org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.j ava:3816)
at
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at
org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3813)
at
org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3789)
at
org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager$7 .widgetSelected(WorkbenchStatusDialogManager.java:1507)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:3543)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1250)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1273)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at
org.eclipse.swt.widgets.Link.textView_clickOnLink_atIndex(Li nk.java:117)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4855 )
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native
Method)
at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:202)
at org.eclipse.swt.widgets.Widget.mouseDown(Widget.java:920)
at org.eclipse.swt.widgets.Control.mouseDown(Control.java:2151)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4653 )
Method)
at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:1 753)
at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:182 5)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4713 )
Method)
at
org.eclipse.swt.widgets.Display.applicationSendEvent(Display .java:4285)
at
org.eclipse.swt.widgets.Display.applicationProc(Display.java :4352)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at
org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApp lication.java:101)
at
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3097)
at
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
"error.txt" 67L, 4894C
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #488654 is a reply to message #488277] Tue, 29 September 2009 11:31 Go to previous messageGo to next message
I'd suggest asking this on the eclipse.platform newsgroup. I've never heard
of this problem before, and don't know what could cause JavaTimeZone to not
initialize.
Grant
"Ralf Buschermoehle" <ralf.buschermoehle@uni-oldenburg.de> wrote in message
news:h9nfhp$g7u$1@build.eclipse.org...
> Hello,
> Greetings,
> Ralf
> at
> at
> at
> at
> at
> at
67)
> at
> at
> at
> at
7)
> at
> at
e.java:595)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Method)
> at
> Method)
> at
> at
> at
1)
> at
> at
> at
> at
> at
> at
java:113)
> at
194)
> at
> at
pLauncher.java:79)
> at
> at
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #529393 is a reply to message #488277] Sat, 24 April 2010 10:38 Go to previous messageGo to next message
Hello
I used to have the same issue in Eclipse Galileo SR2 and the latest beta, moreover when I clicked on "Project properties" it used to show "the currently displayed page contains invalid values" and a blank page. Very annoying.
To solve the issue:
  1. Decompress the com.ibm.icu_4.0.1.v20090822.jar file in the eclipse/plugins folder to any directory you like
    If you cannot find the exact version, just decompress the IBM ICU JAR that's shipped with your version of Eclipse
  2. In that directory, open the file com/ibm/icu/ICUConfig.properties
  3. Replace
    com.ibm.icu.util.TimeZone.DefaultTimeZoneType = JDK
    with
    com.ibm.icu.util.TimeZone.DefaultTimeZoneType = ICU
  4. Recompress the com.ibm.icu_4.0.1.v20090822.jar file in the eclipse/plugins folder with the modified file
Make sure Eclipse is started with a clean cache, and it should work. The easiest way of cleaning the Eclipse cache is to remove the .plugins folder of your workspace.
Cheers
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #635385 is a reply to message #529393] Tue, 26 October 2010 11:47 Go to previous messageGo to next message
Thanks S. Ali Tokmen. You instructions did help.
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #647118 is a reply to message #529393] Tue, 04 January 2011 11:32 Go to previous messageGo to next message
A best way is to add this line in eclipse.ini file :
-Dcom.ibm.icu.util.TimeZone.DefaultTimeZoneType=ICU
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #912086 is a reply to message #647118] Wed, 12 September 2012 19:04 Go to previous messageGo to next message
Thanks vercount! That worked for me too. The new Juno release was broken in Ubuntu, until I put in your ini fix!
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #912113 is a reply to message #912086] Wed, 12 September 2012 20:35 Go to previous messageGo to next message
Clay Ferguson wrote on Wed, 12 September 2012 19:04
I was able to replicate the bug on the command line without using Eclipse. I do not use the Ubuntu managed Eclipse package though, so I can't comment on whether the Eclipse Juno package was also broken. The cause for me was the upgrade of openjdk-7.
Reinstalling tzdata-java was the fix for me:
sudo apt-get --reinstall install tzdata-java
See the Ubuntu Launchpad bug number 1047762 for more details (I can't link to it as I don't have enough reputation)
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #912151 is a reply to message #912113] Wed, 12 September 2012 23:13 Go to previous messageGo to next message
Peter, based on your post, I think you narrowed it down and found the *real* problem. Thanks for sharing!
Further on my scenario: It had to have been the automatic Java upgrade that Ubuntu did, that broke my Eclipse, and was *not* the Eclipse distro itself that was the problem. The reason I was upgrading to Juno, was because Indigo had stopped working. But in reality it was the Java install that was broke. I think I let Ubuntu run some upgrades while something had the java files locked (like MySql instance), and the Java upgrading didn't comlete right. Anyway, this is TMI, but may help others.
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #915602 is a reply to message #912151] Mon, 17 September 2012 12:08 Go to previous messageGo to next message
I had the same problem. I am using Ubuntu Linux. For me, the solution is simple. Install tzdata-java and restart eclipse.
sudo apt-get install tzdata-java
The problem is not in eclipse. The problem is in java configuration.
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #916420 is a reply to message #647118] Tue, 18 September 2012 21:59 Go to previous messageGo to next message
vercout wrote on Tue, 04 January 2011 11:32
Thank you so so much for posting this issue!!! The TimeZoneError was hidden in a very long and discombobulated stack trace, but on a whim I looked it up instead of the top level and found this. I can now read my C files again!!! Very Happy Also running Ubuntu, 12.04 with Open JDK 6.
Re: osx - leopard (no(t) snow) - eclipse 3.5.1 JavaTimeZoneError [message #916463 is a reply to message #916420] Tue, 18 September 2012 23:23 Go to previous message
> C files again!!! :d Also running Ubuntu, 12.04 with Open JDK 6.
reinstalling tzdata-java solves the problem completely so you don't have
to add the line to eclipse.ini
Previous Topic:HTML5 support for SWTBrowser
Next Topic:Which is the latest Xulrunner version supported in SWT version X ?
Current Time: Sun Jul 20 15:15:19 EDT 2025
Powered by FUDForum. Page generated in 0.06069 seconds
