Home » Archived » Sapphire » Disable Sapphire.Restore.Defaults on section
Disable Sapphire.Restore.Defaults on section [message #1239330] Mon, 03 February 2014 19:22 Go to next message
Is there a way to disable the Sapphire.Restore.Defaults action. Would it also remove the Clear action next to a property editor? In our use case, we got a list property, that should not be cleared.
I guess this is possible using a SapphireActionHandlerFilter, but they are only available on property editors, and not on the Section part e.g..
Defining the context explicitly is also not working, but shouldn't it?
<action-handler-filter>
	<impl>RestoreDefaultsActionFilter</impl>
	<context>Sapphire.Section</context>
	<context>Sapphire.ListPropertyEditor</context>
</action-handler-filter>
Filter Looks like this:
public boolean check(SapphireActionHandler handler) {
	return !(handler.getAction().getId().equals("Sapphire.Restore.Defaults"));
Thanks once more.
Re: Disable Sapphire.Restore.Defaults on section [message #1239356 is a reply to message #1239330] Mon, 03 February 2014 21:11 Go to previous messageGo to next message
Is there a way to disable the Sapphire.Restore.Defaults action. [snip] I guess this is possible using a SapphireActionHandlerFilter, but they are only available on property editors, and not on the Section part e.g.
You can use action handler filters on section. I have fixed the missing action settings for sections issue in the sdef editor.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=427336
No, there is no means to remove content from the property editor assist popup. Rather than trying to suppress these actions, you can instead no-op when deleting the list entries that aren't supposed to be deleted within your custom list property binding.
Re: Disable Sapphire.Restore.Defaults on section [message #1239439 is a reply to message #1239356] Tue, 04 February 2014 02:59 Go to previous messageGo to next message
Noop done and working. Thanks.
For the community: First add
@CustomXmlListBinding(impl = CustomListBinding.class)
to your List property and then override:
org.eclipse.sapphire.modeling.xml.StandardXmlListBindingImpl.remove(Resource)
Re: Disable Sapphire.Restore.Defaults on section [message #1239484 is a reply to message #1239356] Tue, 04 February 2014 04:48 Go to previous messageGo to next message
There is one problem with ActionHandlers added on a section, see my comment here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=427336#c2
Re: Disable Sapphire.Restore.Defaults on section [message #1239491 is a reply to message #1239484] Tue, 04 February 2014 04:58 Go to previous message
Got the root element from the part.
The shell can be obtained using the org.eclipse.sapphire.ui.forms.swt.FormComponentPresentation.
So dunno if SectionPresentation is still required for other purposes.
protected Object run(final Presentation context) {
	final Element rootElement = context.part().getModelElement();
	final SapphireDialog dialog = new SapphireDialog(
			((org.eclipse.sapphire.ui.forms.swt.FormComponentPresentation) context).shell(), editElement,
			DefinitionLoader.context(RootModel.class).sdef("Model")
					.dialog("MyDialog"));
	dialog.open();
	switch (dialog.getReturnCode()) {
	case 0:
		// ok
		break;
	case 1:
		// cancel
		break;
	return null;
Previous Topic:Apply read.only to cells at runtime
Next Topic:Button for Sapphire.Jump.Java.Type action handler
Current Time: Tue Oct 28 06:16:01 EDT 2025
Powered by FUDForum. Page generated in 0.25039 seconds
