Where are the connections stored? [message #1164424] |
Thu, 31 October 2013 13:23  |
I have a strange problem ...
The application I wrote works fine when called from eclipse. I then
exported it, lauchned it and added a cnnection. When I then relaunch the
app the connection is lost.
The code I used to create the connection is here:
ISystemRegistry registry = RSECorePlugin.getDefault().getSystemRegistry();
ISystemProfile profile =
registry.getSystemProfileManager().getDefaultPrivateSystemProfile();
IHost host = registry.getHost(profile, hostFieldValue);
if (host == null) {
try {
host =
registry.createHost(RSECorePlugin.getTheCoreRegistry().getSystemTypeById(IRSESystemType.SYSTEMTYPE_SSH_ONLY_ID),
hostFieldValue, hostFieldValue, "Connection to " + hostFieldValue);
} catch (Exception e) {
e.printStackTrace();
When I launch the app and create the connection via the remote systems
view, the connection survives the app restart ...
Any ideas?
Re: Where are the connections stored? [message #1166962 is a reply to message #1164519] |
Sat, 02 November 2013 05:43  |
Am 31.10.13 19:45, schrieb Martin Tauber:
> Am 31.10.13 18:23, schrieb Martin Tauber:
>> if (host == null) {
>> try {
>> host =
>> Any ideas?
> ok I found the place it#s in
> workspace/metadata/plugins/com.eclipse.rse.core
> I also saw that the host file is being created when I create the
> connection and after a while is disapears again ... hm - looks like a
> bug ... since even though the files are gone, the host is still shown in
> the remote systems explorer ....
> any other ideas?
ok I worked around the problem by storeing the connection parameters in
the projects persistent session variables and restoreing the connections
if I don't find them, but this is only a workaround ...
FUDForum. Page generated in 0.04602 seconds
