Home » Eclipse Projects » EclipseLink » The parameter name in the query's selection criteria does not match any parameter name defined in th
The parameter name in the query's selection criteria does not match any parameter name defined in th [message #657595] Thu, 03 March 2011 06:56 Go to previous message
I'm getting this rather lenghty exception and can't make heads or tails of it.
It seems the exception is trying to tell me that I specified a parameter name, that is not present in the query.
So something like "... where a = :a" and then do a query.setParameter("b", ...).
But I never created that query. (Eclipselink 2.2.0).
Local Exception Stack:
Exception [EclipseLink-6094] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.QueryException
Exception Description: The parameter name [relationstandnr] in the query's selection criteria does not match any parameter name defined in the query.
Query: ReadAllQuery(name="iRelationstandToCatsWhereIAmRelationstand " referenceClass=RelationstandToCat sql="SELECT relationstand2catnr, dwhby, dwhmodified, relationstandcatnr, relationstandnr FROM rel
ationstand_to_cat WHERE (relationstandnr = ?)")
at org.eclipse.persistence.exceptions.QueryException.parameterN ameMismatch(QueryException.java:1050)
at org.eclipse.persistence.internal.expressions.ParameterExpres sion.getValue(ParameterExpression.java:246)
at org.eclipse.persistence.internal.databaseaccess.DatabaseCall .translate(DatabaseCall.java:951)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeCall(DatasourceCallQueryMechanism.java:206)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeCall(DatasourceCallQueryMechanism.java:193)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.executeSelectCall(DatasourceCallQueryMechanism.jav a:264)
at org.eclipse.persistence.internal.queries.DatasourceCallQuery Mechanism.selectAllRows(DatasourceCallQueryMechanism.java:64 7)
at org.eclipse.persistence.internal.queries.ExpressionQueryMech anism.selectAllRowsFromTable(ExpressionQueryMechanism.java:2 558)
at org.eclipse.persistence.internal.queries.ExpressionQueryMech anism.selectAllRows(ExpressionQueryMechanism.java:2517)
at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLe velReadQuery(ReadAllQuery.java:410)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute DatabaseQuery(ObjectLevelReadQuery.java:1080)
at org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:808)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute (ObjectLevelReadQuery.java:1040)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAll Query.java:383)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute InUnitOfWork(ObjectLevelReadQuery.java:1126)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2842)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1521)
at org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1503)
at org.eclipse.persistence.internal.indirection.QueryBasedValue Holder.instantiate(QueryBasedValueHolder.java:98)
at org.eclipse.persistence.internal.indirection.QueryBasedValue Holder.instantiateForUnitOfWorkValueHolder(QueryBasedValueHo lder.java:113)
at org.eclipse.persistence.internal.indirection.UnitOfWorkValue Holder.instantiateImpl(UnitOfWorkValueHolder.java:156)
at org.eclipse.persistence.internal.indirection.UnitOfWorkValue Holder.instantiate(UnitOfWorkValueHolder.java:222)
at org.eclipse.persistence.internal.indirection.DatabaseValueHo lder.getValue(DatabaseValueHolder.java:88)
at org.eclipse.persistence.indirection.IndirectList.buildDelega te(IndirectList.java:237)
at org.eclipse.persistence.indirection.IndirectList.getDelegate (IndirectList.java:397)
at org.eclipse.persistence.indirection.IndirectList.size(Indire ctList.java:726)
at org.eclipse.persistence.internal.queries.CollectionContainer Policy.sizeFor(CollectionContainerPolicy.java:177)
at org.eclipse.persistence.mappings.CollectionMapping.mergeInto Object(CollectionMapping.java:1395)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.m ergeIntoObject(ObjectBuilder.java:3254)
at org.eclipse.persistence.internal.sessions.MergeManager.merge ChangesOfCloneIntoWorkingCopy(MergeManager.java:525)
at org.eclipse.persistence.internal.sessions.MergeManager.merge Changes(MergeManager.java:263)
at org.eclipse.persistence.mappings.CollectionMapping.mergeInto Object(CollectionMapping.java:1452)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.mer geCloneWithReferences(UnitOfWorkImpl.java:3467)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUni tOfWork.mergeCloneWithReferences(RepeatableWriteUnitOfWork.j ava:363)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.mer geCloneWithReferences(UnitOfWorkImpl.java:3427)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.merge Internal(EntityManagerImpl.java:452)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.merge (EntityManagerImpl.java:429)
at nl.knowledgeplaza.util.jpa.EntityManagerExtender.invoke(Enti tyManagerExtender.java:384)
at $Proxy4.merge(Unknown Source)
at org.tbee.swing.jpa.JpaObjectNavigatorModel$1.call(JpaObjectN avigatorModel.java:936)
at org.tbee.swing.jpa.JpaObjectNavigatorModel.doSave(JpaObjectN avigatorModel.java:964)
at org.tbee.swing.jpa.JpaObjectNavigatorModel.doSave(JpaObjectN avigatorModel.java:905)
at org.tbee.swing.jpa.JpaObjectNavigatorBar$3.actionPerformed(J paObjectNavigatorBar.java:171)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unk nown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
This is the table definition of relationstand_to_cat:
Column name Type Nulls
relationstand2catnr integer yes
relationstandnr integer no
relationstandcatnr integer no
dwhmodified datetime year to second yes
dwhby integer yes
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Read Message
Previous Topic:Retrieve server generated value
Next Topic:Implementing post merge events
Current Time: Tue Oct 14 07:05:37 EDT 2025
Powered by FUDForum. Page generated in 0.05056 seconds
