Home » Language IDEs » AspectJ » Aspect not applied after adding annotation
Aspect not applied after adding annotation [message #633756] Tue, 19 October 2010 05:50 Go to next message
On our project we are using aspects with pointcut expressed on custom annotation. For example we want to cut all methods with @MyAnnotation annotation.
The problem comes when we first write the method without the annotation, save (=build), then add the annotation, save (=incremental build ?).
In this case the aspect is not applied.
A workaround is to perform a full clean of the project.
I would like to know if this is a known issue and if there is something we can do to avoid needing to clean the project.
Julien
Re: Aspect not applied after adding annotation [message #633885 is a reply to message #633756] Tue, 19 October 2010 13:07 Go to previous messageGo to next message
This sounds like a bug in our incremental compiler. Can you please send a message to the aspectj mailing list and include a small code snippet that describes the failure?
Mailing list is here:
http://eclipse.org/aspectj/userlists.php
Re: Aspect not applied after adding annotation [message #633979 is a reply to message #633885] Wed, 20 October 2010 03:19 Go to previous message
Thanks Andrew, I'll post on the mailing list.
Previous Topic:intertype declarations in separate project
Next Topic:A Request from a Novice
Current Time: Tue Oct 07 17:30:59 EDT 2025
Powered by FUDForum. Page generated in 0.04336 seconds
