Home » Archived » DSDP - Native Application Builder (NAB) » WideStudio build fails on Windows
WideStudio build fails on Windows [message #249] Wed, 15 August 2007 07:44 Go to next message
Originally posted by: weimaomin.gmail.com
I have downloaded wswin396-1.zip and ws-v3.96.1-src.tar.gz at
(http://www.eclipse.org/dsdp/nab/downloads.php) .
And installed wswin396-1.zip successfully on my Windows. Now I want to
compile the source file ws-v3.96.1-src.tar.gz on my machine, but there are
lot's of errors when I run makewin.bat.
My steps is as follows:
1 >cd ws-v3.96-1\src
2. >configure-win.bat
3. >makewin.bat
At step 2, there are many files do not exist, and at step 3 there are more
errors.
Such as:
1) ar -rv ../../lib-st/libws.a ./runtime/master_obj.o
ar: ../../lib-st/libws.a: No such file or directory
make: *** [../../lib-st/libws.a] Error 1
2) WSDwinImage.cpp:36:21: jpeglib.h: No such file or directory
WSDwinImage.cpp:37:17: png.h: No such file or directory
WSDwinImage.cpp:198: field `pub' has incomplete type
WSDwinImage.cpp:199: 'jmp_buf' is used as a type, but is not defined as
a type.
3) C:\ws-v3.96-1\src>cd nwin
指定されたパスが見つかりません。
Then I create a directory /src/lib-st, and delete the follows at makewin.bat
files (there are no nwin and wsagent-local directory at all):
cd nwin
make -f make.win all
cd ..
cd wsagent-local
make all
cd
And run makewin.bat again, but there are a lot of errors also.
Thanks.
/weimaomin
Re: WideStudio build fails on Windows [message #260 is a reply to message #249] Fri, 17 August 2007 03:11 Go to previous messageGo to next message
The tar ball that you got is Linux source.
There is no need to build on Windows.
You can use NAB by only wswin396-1.zip.
Is this answer enough to you?
Shigeki
weimaomin wrote:
> are lot's of errors when I run makewin.bat.
> 3. >makewin.bat
> more errors.
> Such as:
> as a type.
> 指定されたパスが見つかりません。
> makewin.bat files (there are no nwin and wsagent-local directory at all):
> cd nwin
> cd ..
> cd wsagent-local
> make all
> cd
> Thanks.
> /weimaomin
Re: WideStudio build fails on Windows [message #268 is a reply to message #260] Wed, 22 August 2007 02:33 Go to previous messageGo to next message
Hi, Shigeki Moride
First, I introduce my work.:
I'm a new programmer. Now my work is to analysis the relation of NAB and
MWT.
Such as, how to generate code when I drag a button on the Eclipse with NAB
and MWT,
how to add a new control (just like button control) to the NAB, and let it
gererate code when
I drag it(the new control) to the newwin.
So, I need to modify the source file of MWT, and recompile it to dll and
check the result.
But now, I cannot compile the MWT source file successfully.
Someone reply me that I should use the source which wswin396-1.zip contains
for Windows,
not ws-v3.96.1-src.tar.gz.
I do it as above, but just fewer errors than before.
In fact, some directory can compile to dll successfully, some not.
For example, when I make win directory,
>cd win
the errors as follows:
WSDwinImage.cpp:36:45: jpeglib.h: No such file or directory
WSDwinImage.cpp:37:36: png.h: No such file or directory
but they already exist at [C:\Program Files\WideStudio\others\win32\jpeglib]
and [C:\Program Files\WideStudio\others\win32\libpng],
then I copy "jpeglib.h, png.h, jconfig.h, jmorecfg.h" to the source file
directory [C:\ws\include]
and make again, the errors as follows:
In file included from ../../include/jpeglib.h:37,
from WSDwinImage.cpp:36:
.../../include/jmorecfg.h:165: conflicting types for `typedef long int INT32'
C:/PROGRA~1/WIDEST~1/gcc/include/basetsd.h:52: previous declaration as
`typedef
int INT32'
In file included from WSDwinImage.cpp:36:
.../../include/jpeglib.h:105: 'boolean' is used as a type, but is not defined
as
a type.
Shigeki Moride, could you tell me how to compile the all directories
successfully ?
"Shigeki Moride" <moride.shigeki@jp.fujitsu.com> wrote in message
news:fa3hn5$rrm$1@build.eclipse.org...
> Shigeki
> weimaomin wrote:
>> 3. >makewin.bat
>> more errors.
>> Such as:
>> as a type.
>> 指定されたパスが見つかりません。
>> cd nwin
>> cd ..
>> cd wsagent-local
>> make all
>> cd
>> Thanks.
>> /weimaomin
Re: WideStudio build fails on Windows [message #277 is a reply to message #268] Tue, 28 August 2007 03:43 Go to previous messageGo to next message
Hi, weimaomin
Firstly, I'm sorry for slow response.
I have tried on same version.
But, I couldn't get same result.
OK, I have some suggestions.
1. Please run a WideStudio/ws/src/configure-win.bat firstly.
2. Please edit and run a WideStudio/ws/src/makewin.bat
- Maybe it contains unnecessary parts such as ruby java ocam and etc.
Please comment out such part you need.
3. If you use Localized Windows other than Japanese, perhaps you get
some errors based on Locale.
Then please try on English Windows.
I think this behavior is problem of deployment for worldwide users.
We needs help as you :-)
Shigeki,
weimaomin wrote:
> Hi, Shigeki Moride
> MWT.
> NAB and MWT,
> it gererate code when
> check the result.
> contains for Windows,
>> cd win
> INT32'
> `typedef
> int INT32'
> defined as
> a type.
> successfully ?
>> Shigeki
>> weimaomin wrote:
>>> Hi,
>>> 3. >makewin.bat
>>> more errors.
>>> Such as:
>>> as a type.
>>> 指定されたパスが見つかりません。
>>> all):
>>> cd nwin
>>> cd ..
>>> cd wsagent-local
>>> make all
>>> cd
>>> Thanks.
>>> /weimaomin
oVMhuQHDEcrgldn [message #1141 is a reply to message #277] Fri, 22 August 2008 00:00 Go to previous messageGo to next message
Originally posted by: ruvhkq.oyavdj.com
z8dODi <a href="http://lvkwswpgoqty.com/">lvkwswpgoqty</a>,
jlsevdycrigc,
wrchoilgbmhz[/link],
http://maqlisvjtcxu.com/
MTsfsTQhdfbczHO [message #1167 is a reply to message #260] Fri, 22 August 2008 00:00 Go to previous messageGo to next message
Originally posted by: ilwkrx.txpzgk.com
pzxb83 <a href="http://tlpkwgteeozh.com/">tlpkwgteeozh</a>,
havvttiqjmvo,
gmizrrrnradr[/link],
http://bltdqwmtntaj.com/
mQQvzTQavlCq [message #1194 is a reply to message #249] Fri, 22 August 2008 00:01 Go to previous message
Originally posted by: poiapj.ykwxex.com
8flP8A <a href="http://yxeijtbitdwa.com/">yxeijtbitdwa</a>,
ggrwpiopljkh,
kudtlgokkwwp[/link],
http://lfaxtggzunhd.com/
Re: WideStudio build fails on Windows [message #568979 is a reply to message #249] Fri, 17 August 2007 03:11 Go to previous message
Shigeki
weimaomin wrote:
> 3. >makewin.bat
> more errors.
> Such as:
> as a type.
> 指定されたパスが見つかりません。
> cd nwin
> cd ..
> cd wsagent-local
> make all
> cd
> Thanks.
> /weimaomin
Re: WideStudio build fails on Windows [message #569034 is a reply to message #260] Wed, 22 August 2007 02:33 Go to previous message
Hi, Shigeki Moride
MWT.
and MWT,
gererate code when
check the result.
for Windows,
>cd win
`typedef
int INT32'
as
a type.
successfully ?
> Shigeki
> weimaomin wrote:
>> 3. >makewin.bat
>> more errors.
>> Such as:
>> as a type.
>> 指定されたパスが見つかりません。
>> cd nwin
>> cd ..
>> cd wsagent-local
>> make all
>> cd
>> Thanks.
>> /weimaomin
Re: WideStudio build fails on Windows [message #569061 is a reply to message #268] Tue, 28 August 2007 03:43 Go to previous message
Hi, weimaomin
Shigeki,
weimaomin wrote:
> Hi, Shigeki Moride
> MWT.
> NAB and MWT,
> check the result.
>> cd win
> INT32'
> `typedef
> int INT32'
> defined as
> a type.
> successfully ?
>> Shigeki
>> weimaomin wrote:
>>> Hi,
>>> 3. >makewin.bat
>>> more errors.
>>> Such as:
>>> as a type.
>>> 指定されたパスが見つかりません。
>>> all):
>>> cd nwin
>>> cd ..
>>> cd wsagent-local
>>> make all
>>> cd
>>> Thanks.
>>> /weimaomin
oVMhuQHDEcrgldn [message #569530 is a reply to message #277] Fri, 22 August 2008 00:00 Go to previous message
jlsevdycrigc,
MTsfsTQhdfbczHO [message #569577 is a reply to message #260] Fri, 22 August 2008 00:00 Go to previous message
havvttiqjmvo,
mQQvzTQavlCq [message #569622 is a reply to message #249] Fri, 22 August 2008 00:01 Go to previous message
ggrwpiopljkh,
Previous Topic:Next NAB release
Next Topic:Next NAB release
Current Time: Sat Nov 08 22:50:07 EST 2025
Powered by FUDForum. Page generated in 0.07866 seconds
