Home » Archived » BIRT » Suggestion for ODACONFIG.XML
Suggestion for ODACONFIG.XML [message #24013] Thu, 31 March 2005 10:39 Go to next message
Right now odaconfig.xml contains the following:
<RunTimeInterface>
<InterfaceType>Java</InterfaceType>
<DriverInitEntryPoint>org.eclipse.birt.report.data.oda.jdbc.JDBCConnectionFa
ctory</DriverInitEntryPoint>
<DriverLibraries>
<LibrariesForOS>
<OSType>All</OSType>
<LibraryName>oda-jdbc.jar</LibraryName>
</LibrariesForOS>
<SetJavaThreadContextClassLoader>false</SetJavaThreadContextClassLoader >
</DriverLibraries>
</RunTimeInterface>
I suggest adding under LibrariesForOS a new node LibraryDir as in the
following example
<RunTimeInterface>
<DriverLibraries>
<LibrariesForOS>
</LibrariesForOS>
<LibrariesForOS>
<OSType>Windows</OSType>
<LibraryDir>c:\birt\jdbc</LibraryDir>
</LibrariesForOS>
<LibrariesForOS>
<OSType>LINUX</OSType>
<LibraryDir>/var/eclipse/birt/jdbc</LibraryDir>
</LibrariesForOS>
</DriverLibraries>
</RunTimeInterface>
Any jar file found in the library directory would then be added to the
library list as if it had been explicitly stated in a <LibraryName> node.
This would drastically simplify setup and configuration of birt.
Re: Suggestion for ODACONFIG.XML [message #24238 is a reply to message #24013] Thu, 31 March 2005 17:04 Go to previous messageGo to next message
Thierry,
Thanks for the input.
In the current odaconfig schema definition (located in the source tree
under org.eclipse.birt.data/schema/ODAConfig.xsd ), the
<LibrariesForOSType> includes an optional <Location> element. This is for
the folder location of the files listed under <LibraryName>.
With that said, the scheme is going to change though...
In response to the feedback we received from the community, we plan to
move the ODA driver configuration info to the Eclipse plugin manifest
directly. The run-time libraries will be listed in an ODA extension
plugin.xml's <runtime> element, and their class loading will be handled by
the Eclipse class loading framework via OSGi.
This feature is planned to be available in April.
Any feedback on this planned enhancement will be much appreciated.
Linda
Re: Suggestion for ODACONFIG.XML [message #24281 is a reply to message #24238] Thu, 31 March 2005 19:24 Go to previous message
The biggest issue that I see is the relative complexity of providing BIRT to
only semi-technical people and still being able to provide different JDBC
drivers simply. Anything which would require editing a file found under
ECLIPSE_HOME would be a bad thing. I'd like to be able to provide BIRT to
our semi-technical people running under Eclipse platform, and to be able to
take full advantage of update sites to allow them to stay up-to-date. We
would need to be able to provide jdbc drivers for DB2/AS400, Oracle, and
MySQL What I would consider ideal would be the ability to create an eclipse
plugin which would contain a JDBC driver and register it into ODA. (In
fact, I've got some source code that does this - but it is from before a
couple of CVS reorganizations so I'd have to work through it again.)
From a runtime point of view, I'd like to have a BIRT service running under
Websphere, and it seems to me that a different type of additivity would be
needed for that. And I'd like to see that installation and configuration to
be as plug-and-play as possible also - ideally by deploying an ear file.
The primary intent of my suggestion was to be able to specify a directory
that JDBC driver jar files could be placed into without having to name the
jar files explicitly - very similar in concept to the way WEB-INF/lib
behaves for a servlet container. The same mechanism could have worked both
within Eclipse and in a BIRT servlet context.
"Linda Chan" <lchan@actuate.com> wrote in message
news:72b7ec5429d0c3b539ea5cb371829526$1@www.eclipse.org...
> Thierry,
> Linda
Previous Topic:stored procedure
Next Topic:Japanese character can not be wrapped in generated PDF
Current Time: Sat Nov 08 12:33:52 EST 2025
Powered by FUDForum. Page generated in 0.02906 seconds
