Home » Eclipse Projects » Eclipse Platform » Lomboz Plugin Problem
Lomboz Plugin Problem [message #243259] Fri, 21 May 2004 13:40 Go to next message
Has anyone gotten the Lomboz plugin to work with Eclipse 2.1.3? If so,
how did you install the plugin? Also, which version of Lomboz did you
install?
I tried to install Lomboz 213 into Eclipse 2.1.3 by copying the
com.objectlearn.jdt.j2ee.editors directory (from Lomboz) into the
Eclipse plugin directory. However, when I re-started Eclipse, it did
not find/recognize Lomboz.
Thanks very much.
Dom
Re: Lomboz Plugin Problem [message #243278 is a reply to message #243259] Fri, 21 May 2004 15:07 Go to previous message
Dom Incollingo wrote:
> Hello,
> install?
> Thanks very much.
> Dom
I just found out that I have to extract the lomboz.213.zip file into the
Eclipse home directory. That worked. Thanks.
Previous Topic:About Plugin features
Next Topic:Automatic addition of missing tags to all methods
Current Time: Sat Nov 08 21:03:52 EST 2025
Powered by FUDForum. Page generated in 0.03078 seconds
