Home » Language IDEs » Java Development Tools (JDT) » How to prevent Eclipse from automatically completing an XML comment?
How to prevent Eclipse from automatically completing an XML comment? [message #238929] Sat, 16 December 2006 18:32 Go to next message
Originally posted by: james_adams.yahoo.com
I want to configure Eclipse so that it will stop automatically completing
an XML comment when I start typing one. For example if I want to comment
a section of XML then I want to type "<!--" at the top of the section and
then "-->" at the bottom. However as soon as I type the "<!--" Eclipse
automatically finishes the comment for me with a "-->". It's a minor
annoyance that I'd like to configure away if possible. I have tried
numerous preference settings -- turning off content assist for XML and
HTML files, removing the XML comment template, etc. -- but nothing I've
tried so far has turned off this annoying behavior. Can someone suggest
something else I might try?
Thanks in advance for any suggestions.
--James
Re: How to prevent Eclipse from automatically completing an XML comment? [message #239007 is a reply to message #238929] Mon, 18 December 2006 19:34 Go to previous message
I have discovered that there is a WebTools-specific newsgroup/forum to
which this question is more relevant, hence I have reposted there. Sorry
for posting to the wrong group.
--James
Previous Topic:Adding the JRE to the class path programmatically
Next Topic:Incompatible change to Java compiler: JDT stance?
Current Time: Thu Oct 16 23:03:15 EDT 2025
Powered by FUDForum. Page generated in 0.03403 seconds
