Home » Eclipse Projects » Equinox » Plug-in Registry Resolution Document
Plug-in Registry Resolution Document [message #23383] Thu, 24 April 2003 13:49
PaScaL pointed me at the following registry resolution document. I'm
posting it here as an aid for anyone working in this area.
Keith
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/docs/plugin-registry-changes/registry-resouti on.html
Plug-in registry resolution
Last update: April 23, 2003
This document is intended as a home for gathering as much information
about the expected semantics for the registry resolution algorithm as
possible. The goal is to keep this knowledge separately from the
implementation (which may tell a different story), in order to make easier
for developers to enhance/fix it or to develop a new algorithm for
registry resolution. Comments and improvements are welcome.
Soft pre-requisites
Soft pre-requisites are pre-requisites whose "optional" clause is "true".
Unsatisfied optional pre-requisites should be ignored (handled in the same
way as if they didn't exist at all).
An optional pre-requisite will be ignored if any of the following
conditions apply:
* the required plug-in does not exist at all;
* the required plug-in does exist but there are no versions compatible
with the required version;
* the required plug-in exists and there is a version compatible with
the required version but the addition of this plug-in would cause a
conflict. A conflict arises if more than one version of a given plug-in
are required by other plug-ins, the versions are not compatible with each
other, and at least one of the versions is not a library plug-in.
If an optional pre-requisite is ignored for any of the reasons listed
above no error message is generated (but an informational message may be
output to indicate that this pre-requisite is being ignored). Ignoring an
optional pre-requisite does not cause any plug-ins to be disabled. This
causes potential error conditions to be more complex. Each time we have a
situation where we have a conflict, we must first check to see if this is
an optional pre-requisite.
Version matching
The following applies for both plug-in pre-requisites and fragments
matching their associated plug-ins.
Versions have the following form: major.minor.service.qualifier, where
major, minor and service are integers and qualifier is a string.
Version Numbers are matched as follows:
* if no version number is specified, pick the latest version that
satisfies any other related constraints (which is not necessarily the
latest one available in the registry);
* perfect Version (a.b.c.q is a perfect match with d.e.f.r) if:
a = d and b = e and c = f and q = r
* equivalent Version (a.b.c.q is an equivalent match with d.e.f.r) if:
a = d and b = e and ((c > f) or (c = f and q >= r))
* compatible Version (a.b.c.q is compatible with d.e.f.r) if:
a = d and ((b > e) or (b = e and c > f) or (b = e and c = f and q >=
r))
* greaterOrEqual Version (a.b.c.q is a higher version than d.e.f.r)
if:
a > d or (a = d and b > e) or (a = d and b = e and c > f) or (a = d
and b = e and c = f and q >= r)
Also:
Two or more versions of the same plug-in can only be simultaneously
enabled if they all are library plug-ins (they do not expose extension
points nor contribute extensions).
If a highest version of a plug-in is disabled for some reason, the new
highest version (if available) should replace it (when possible) - all
plug-ins (not fragments) that required the disabled version should refer
to the new one.
Questions to be answered
1. What happens if a fragment contributes pre-requisites to a plug-in
that has multiple versions, and these pre-requisites cannot be satisfied?
Currently, the association of a fragment and a plug-in happens before the
resolution itself starts. So if a plug-in a fragment contributes to is
disabled, the fragment is lost (we don't try the next highest version).
Should we? This would cause all versions compatible with the fragment to
be successively disabled, if the fragment contributes unsatisfiable
pre-requisites. Do we want that?
Current registry resolution algorithm (RegistryResolver#resolve)
The existing resolution algorithm works based on a directed graph whose
nodes represent all versions of a given plug-in, and arc from "a" to "b"
means plug-in "a" requires plug-in "b". The algorithm starting point is a
set of root vertices (in-degree is 0) - plug-ins that are not required by
any other plug-ins. The resolution is done through a depth-first traversal
of the graph from the roots to their pre-requisites.
1. Initial state: Registry initially contains all plug-ins and
fragments discovered by the platform - no checking of pre-requisites has
been done.
2. Model objects that are missing mandatory fields are ignored
(#required*)
3. Create a map of plug-in descriptors where for each plug-in id there
is a list of plug-in descriptors that have the same id, ordered by plug-in
version, higher to lower (#add)
4. For each fragment in the registry, add it to the list of fragments
of the right plug-in descriptor (the highest version that fits the
matching criteria) (#linkFragments).
5. For each plug-in which has a fragment:
* For each fragment in the plug-in's fragment list (the highest
version only), add extensions, extension points, libraries and
pre-requisites to the plug-in (#resolvePluginFragments).
6. Create a set with the identifiers of all root plug-ins in the
registry.
7. If there are no roots, there is circularity - all plug-ins are
disabled and the process is finished (registry is emptied if it was to be
trimmed).
8. For each plug-in identifier in the current set of roots:
* Look for the right version(s) to enable, doing a depth-first
traversal in its children (plug-ins that require it). This includes
ensuring:
o all mandatory pre-requisites are satisfied (considering
versions and match clauses);
o there are no conflicts (no different versions are
required simultaneously of plug-ins that provide extensions/extension
points).
o if a root is disabled, its direct children are promoted
to roots if they are not required by any other plug-ins.
9. If the registry is to be trimmed, delete any plug-ins which are not
enabled/do not have pre-requisites satisfied (#resolvePluginRegistry).
10. If the registry is to be linked, link extensions to the targetted
extension points (#resolvePluginRegistry).
Problems in the current registry resolution algorithm
1. all versions of a plug-in are disabled when the version in use
causes a conflict - when a plug-in is disabled for causing a conflict, if
there are different versions available, the highest one should be selected
and the resolution should try to enable that one;
2. order should not matter - for instance, when a conflict is detected,
all plug-ins involved should be disabled not only the one that introduced
the conflict (bug 34752);
3. fragments not associated with a plug-in or fragments not used
because another version of the same fragment exists should be trimmed when
the user requests it and currently are not (bug 33911).
4. the resulting plug-in descriptor should indicate which portions came
from fragments (feature request 23165).
Previous Topic:Questions about OSGi
Next Topic:How do you handle library classes via dependencies?
Current Time: Tue Nov 04 00:08:24 EST 2025
Powered by FUDForum. Page generated in 0.88158 seconds
