| Exception from Edit Driver Definition dialog - DTP 1.0 RC0 build [message #23343] |
Tue, 21 November 2006 18:48 |
I seem to get this exception when I try to create a connection. Log as bug ?
Anthos
org.eclipse.core.runtime.CoreException: Plug-in
oracle.dbtools.connectivity was unable to load class
org.eclipse.datatools.connectivity.ui.PasswordTextPropertyDe scriptor.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:165)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:149)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.datatools.connectivity.internal.ui.DriverInstanc ePropertySource.getPropertyDescriptors(DriverInstancePropert ySource.java:97)
org.eclipse.ui.views.properties.PropertySheetEntry.computeMe rgedPropertyDescriptors(PropertySheetEntry.java:168)
org.eclipse.ui.views.properties.PropertySheetEntry.refreshCh ildEntries(PropertySheetEntry.java:537)
org.eclipse.ui.views.properties.PropertySheetEntry.refreshFr omRoot(PropertySheetEntry.java:599)
org.eclipse.ui.views.properties.PropertySheetEntry.refreshFr omRoot(PropertySheetEntry.java:601)
org.eclipse.ui.views.properties.PropertySheetEntry.setValue( PropertySheetEntry.java:733)
org.eclipse.ui.views.properties.PropertySheetEntry.applyEdit orValue(PropertySheetEntry.java:147)
org.eclipse.ui.views.properties.PropertySheetEntry$1.applyEd itorValue(PropertySheetEntry.java:104)
at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 05)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(Ce llEditor.java:303)
at org.eclipse.jface.viewers.CellEditor.focusLost(CellEditor.ja va:682)
org.eclipse.jface.viewers.TextCellEditor$5.focusLost(TextCel lEditor.java:185)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:109)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:933)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1970)
at org.eclipse.swt.widgets.Widget.wmKillFocus(Widget.java:1671)
at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:35 75)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3277 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:1841)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4025 )
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.j ava:183)
at org.eclipse.swt.widgets.Shell.open(Shell.java:997)
at org.eclipse.jface.window.Window.open(Window.java:792)
org.eclipse.datatools.connectivity.internal.ui.dialogs.Excep tionHandler.showException(ExceptionHandler.java:25)
org.eclipse.datatools.connectivity.internal.ui.DriverInstanc ePropertySource.getPropertyDescriptors(DriverInstancePropert ySource.java:118)
org.eclipse.jface.viewers.TextCellEditor.handleDefaultSelect ion(TextCellEditor.java:294)
org.eclipse.jface.viewers.TextCellEditor$1.widgetDefaultSele cted(TextCellEditor.java:147)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:97)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.datatools.connectivity.internal.ui.dialogs.Drive rDefinitionsDialog.addDriver(DriverDefinitionsDialog.java:55 2)
org.eclipse.datatools.connectivity.internal.ui.dialogs.Drive rDefinitionsDialog.access$700(DriverDefinitionsDialog.java:6 6)
org.eclipse.datatools.connectivity.internal.ui.dialogs.Drive rDefinitionsDialog$2.widgetSelected(DriverDefinitionsDialog. java:223)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
org.eclipse.datatools.connectivity.internal.ui.DriverListCom bo$EditButtonSelectionChangedListener.widgetSelected(DriverL istCombo.java:629)
org.eclipse.datatools.connectivity.ui.actions.AddProfileView Action.run(AddProfileViewAction.java:125)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
org.eclipse.core.runtime.CoreException[1]:
java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
FUDForum. Page generated in 0.05781 seconds
