Home » Eclipse Projects » Equinox » Other OSGi questions
Other OSGi questions [message #23338] Mon, 21 April 2003 15:08 Go to next message
Here some extra questions about OSGi:
- What happens if a bundle is leaving and the service it provides are not
unregistered?
It seems to me that the framework automatically "unregister" it, isn't
it?
- Bundle A is active and imports package foo, Bundle B exports package foo.
So A uses instances from B.
1st question - What happens if a Bundle C is being installed and exports
foo?
2nd question - What happens if B is being updated?
Thank you
PaScaL
Re: Other OSGi questions [message #23426 is a reply to message #23338] Thu, 24 April 2003 14:10 Go to previous messageGo to next message
Pascal,
Based on my reading of the OSGi Release 3 Spec
>> unregistered? It seems to me that the framework automatically
"unregister" it,
>> isn't it?
Section 4.8.7 (Stopping Bundles). The framework must automatically
unregister
all register services when the bundle is stopped.
foo.
exports foo?
Section 4.4 (The Bundle name-space). It's my understanding that if a
package is
exported by multiple bundles, the framework selects the package from one
of the
bundles. There's verbage pointing out than an "export" is an implicit
"import"
and even though a bundle exports a package, it may use a different
(potentially
lower version) of that package. Note also, packages can be used from a
bundle
without the bundle being activated.
Section 4.8.9 (Updating Bundles). If an updated bundle had exported any
packages
that are used by other bundles, those packages may not be updated; their
old
versions remain exported until the xxx.refreshPackages method has been
called
or the Framework is restarted.
Re: Other OSGi questions [message #23638 is a reply to message #23338] Sat, 26 April 2003 10:27 Go to previous message
Originally posted by: Peter.Kriens.aQute.se
> unregistered?
> it?
Yes. After the bundle's stop() method is called, the framework
automatically unregisters any remaining services.
> foo?
The framework already has an import for foo so it will not do anything.
After update - nothing is changed. But normally after one or more
updates, refreshPackages() is called and this will resolve all
dependencies again. Depending on versions, C might be choosen or B
again. (Bundles that depend on this package, like A, will be restarted
in that case).
Kind regards,
Peter Kriens
> Thank you
> PaScaL
Previous Topic:How do you handle library classes via dependencies?
Next Topic:Equinox and the next Eclipse
Current Time: Sat Nov 08 05:22:38 EST 2025
Powered by FUDForum. Page generated in 0.06999 seconds
