Home » Archived » BIRT » MySQL column Alias Problem
MySQL column Alias Problem [message #236717] Wed, 02 May 2007 09:19 Go to next message
Originally posted by: dwarak.orangescape.com
I am using MySQL as my Datasource (MySQL Connector/J driver). When I write a
query with an alias (e.g. select my_column_name as 'My Column Name' from
myTable then the resultant column name is displayed as unnamed_1 instead of
"My Column Name". If anyone has a solution for this issue it will be of
great help.
Dwarakanath
Re: MySQL column Alias Problem [message #236760 is a reply to message #236717] Thu, 03 May 2007 12:13 Go to previous message
Hello Dwarakanath,
Try to drop the as from the select clause:
Select
t.c1 cust_first_name,
t.c2 cust_last_name
from
table t
Scott Rosenbaum
> Hi
> write a query with an alias (e.g. select my_column_name as 'My Column
> Name' from myTable then the resultant column name is displayed as
> unnamed_1 instead of "My Column Name". If anyone has a solution for
> this issue it will be of great help.
> Regards
> Dwarakanath
Previous Topic:Report in a Browser widget renders differently or empty
Next Topic:ChartWizardLauncher in chart examples
Current Time: Sat Nov 08 20:38:53 EST 2025
Powered by FUDForum. Page generated in 0.03789 seconds
