Home » Archived » EPF » Search Feature
Search Feature [message #22744] Wed, 08 November 2006 04:53 Go to next message
When we publish the process, we are not getting any search feature. But in
the help on Publishing the process, it's mentions that select, glossary,
Search Index are available for publishing. But even in the publish wizard,
there is no option to select search as a feature.
Any help on this??
Re: Search Feature [message #22833 is a reply to message #22744] Wed, 08 November 2006 14:40 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Search functionality on published site is not available in open source
version. Sorry.
Shilpa
Re: Search Feature [message #23051 is a reply to message #22744] Thu, 09 November 2006 19:39 Go to previous messageGo to next message
You can add glossary items by creating a guidance type called Term. All
Terms will appear in the glossary sorted alphabetically. The Glossary is
accessed from the button in the upper right of the browser window, on
the ribbon.
Indexes are harder. You have to add anchors and special HTML to the
location in the content where you want to jump to when the user selects
the index item. See the help topic "Creating Index Entries" in the EPF
Composer. The Index button is next to the Glossary button.
The generic Search feature is not part of EPF Composer.
Jim Ruehlin
jruehlin@us.ibm.com
> But in the help on Publishing the process, it's mentions that select,
> glossary, Search Index are available for publishing. But even in the
> publish wizard, there is no option to select search as a feature.
> Any help on this??
Re: Search Feature [message #23314 is a reply to message #23051] Sat, 11 November 2006 17:56 Go to previous messageGo to next message
Originally posted by: markjdickson.googlemail.com
This is a long running issue. The original search facility in RMC was (as
I understand it) provided by the Java applet, which was not part of the
IBM donation to EPF. So far, we have not produced replacement
functionality to provide search through the published content.
There was a bugzilla raised on this issue quite a while ago
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=139906).
I think that this is a popular issue - it's usually the first thing I get
asked by new users of published content.
If (like me) you want to see this feature included in a future release of
the product then there are several ways to achieve this;
1. reply to this thread, indicating your support for including the feature
2. vote on the bugzilla mentioned above
3. write the code required to provide the feature and contribute it to EPF
by attaching it to the bugzilla
Method 3 is preferred but one of the other two will do ;-)
cheers
Mark Dickson
Re: Search Feature [message #24432 is a reply to message #23314] Wed, 22 November 2006 09:47 Go to previous messageGo to next message
Mark,
Here is my vote to get this resolved :)
> of the product then there are several ways to achieve this;
> feature
Re: Search Feature [message #25849 is a reply to message #23314] Tue, 19 December 2006 16:53 Go to previous message
I, too, would like to see Search provided - I thought I had missed
something.
Rob
"Mark Dickson" <markjdickson@googlemail.com> wrote in message
news:4a833db3d29e4c3e815d7933a7e7f004$1@www.eclipse.org...
> Hi
> cheers
> Mark Dickson
Re: Search Feature [message #567810 is a reply to message #22744] Wed, 08 November 2006 14:40 Go to previous message
version. Sorry.
Shilpa
Re: Search Feature [message #567964 is a reply to message #22744] Thu, 09 November 2006 19:39 Go to previous message
the ribbon.
Jim Ruehlin
jruehlin@us.ibm.com
> Any help on this??
Re: Search Feature [message #568184 is a reply to message #23051] Sat, 11 November 2006 17:56 Go to previous message
cheers
Mark Dickson
Re: Search Feature [message #568977 is a reply to message #23314] Wed, 22 November 2006 09:47 Go to previous message
Mark,
> feature
Re: Search Feature [message #574265 is a reply to message #23314] Tue, 19 December 2006 16:53 Go to previous message
something.
Rob
> Hi
> cheers
> Mark Dickson
Previous Topic:Please Provide Feedback on OpenUP
Next Topic:is ther any Workflow engine in epf?
Current Time: Thu Nov 06 05:16:42 EST 2025
Powered by FUDForum. Page generated in 0.14190 seconds
