Home » Eclipse Projects » Remote Application Platform (RAP) » Font size calculation
Font size calculation [message #22483] Mon, 07 May 2007 08:09 Go to next message
I know that font size calculation is planned for M5, but it has I high
priority for me, as the "close view" action is not always visible depending
on the characters used in the title. Maybe you could fix this issue a little
bit earlier.
Markus
Re: Font size calculation [message #22784 is a reply to message #22483] Mon, 07 May 2007 16:13 Go to previous messageGo to next message
Originally posted by: jkrause.innoopract.com
Hi Markus,
Could you please provide a couple of problematic strings (with font and
size).
Jochen
Markus Krüger wrote:
> Hello,
> bit earlier.
> Best regards,
> Markus
Re: Font size calculation [message #23046 is a reply to message #22784] Tue, 08 May 2007 06:07 Go to previous messageGo to next message
Hello Jochen,
I think it has to do with the character "w" or "W". I use the character
several times in the name. I wanted to name a View "World Wide Web Browser"
which maybe seems to you a little bit strange.I didn't like it either as I
saw the title in the view, but that's a String where You do not see the
close-image anymore. I changed my title now to "Web Browser" wich I will use
now as the close-image is visible now but it is still miss-placed somehow.
It is too far to the right edge of the view tab. You can reproduce it as You
change the title of Your demo view "View I" to the titles mentioned above. I
did not change any font setting.
Thank you in advance,
Markus
"Jochen Krause" <jkrause@innoopract.com> schrieb im Newsbeitrag
news:f1o18l$lts$2@build.eclipse.org...
> Hi Markus,
> size).
> Jochen
> Markus Kr
Re: Font size calculation [message #32914 is a reply to message #23046] Wed, 13 June 2007 08:08 Go to previous messageGo to next message
Now I also have the problem with the perspective switcher and it does not
look good for our customers.
You can reproduce this by the name a view "Webbrowser", wich leads to the
missplaced close button, and to name one perspective "Basis" and the other
one "Report Viewer" (which relly looks bad). Could You add some extra pixels
to it for now, to make it work for me, or could You tell me where I have to
add the extra pixels?
Markus
"Markus Kr
Re: Font size calculation [message #33018 is a reply to message #32914] Wed, 13 June 2007 11:57 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Markus,
you could either add some extra space characters at the end of your text
or hack the FontSizeEstimation class.The getAvgCharWidth(Font) method
does the actual "calculation".
Hop that helps
Rüdiger
> Markus
> "Markus Krüger" <krueger@ion.ag> schrieb im Newsbeitrag
> news:f1pi2l$b3$1@build.eclipse.org...
>> Hello Jochen,
>> Browser" which maybe seems to you a little bit strange.I didn't like it
>> either as I saw the title in the view, but that's a String where You do
>> not see the close-image anymore. I changed my title now to "Web Browser"
>> wich I will use now as the close-image is visible now but it is still
>> miss-placed somehow. It is too far to the right edge of the view tab. You
>> can reproduce it as You change the title of Your demo view "View I" to the
>> titles mentioned above. I did not change any font setting.
>> Markus
>>> Hi Markus,
>>> size).
>>> Thanks,
>>> Jochen
>>>> Hello,
>>>> depending on the characters used in the title. Maybe you could fix this
>>>> issue a little bit earlier.
>>>> Best regards,
>>>> Markus
Re: Font size calculation [message #33054 is a reply to message #33018] Thu, 14 June 2007 05:05 Go to previous messageGo to next message
Hi R
  • Attachment: persp.gif
    (Size: 4.55KB, Downloaded 150 times)
Re: Font size calculation [message #33057 is a reply to message #33054] Thu, 14 June 2007 05:32 Go to previous messageGo to next message
Hi Markus,
this is a known problem. The CoolItem in this thing is cut because we
don't support a chevron on CoolItems yet.
See bug 190071 and 190072
Cheers
Benny
> Hi Rüdiger,
> I added the line
> width = width + 0.5f;
> to the getAvgCharWidth(Font) method. The name of the view is now displayed
> better, but the perspectivebar still looks bad if I open a second
> perspective. You can reproduce this in the demo as described below. The
> default perspective open is "Basis". Now, if I open my perspective "Report
> Viewer" then the text is still cut of as shown in the atteched screen shot.
> Maybe the perspective bar does not resize corretly?
> Markus
> "Rüdiger Herrmann" <rherrmann@innoopract.com> schrieb im Newsbeitrag
> news:f4p452$475$1@build.eclipse.org...
>> Hi Markus,
>> Hop that helps
>> Rüdiger
>>> other
>>> pixels
>>> to
>>> Regards,
>>> Markus
>>>> Hello Jochen,
>>>> You
>>>> the
>>>> Markus
>>>>> Hi Markus,
>>>>> size).
>>>>> Thanks,
>>>>> Jochen
>>>>>> Hello,
>>>>>> this
>>>>>> Best regards,
>>>>>> Markus
Re: Font size calculation [message #33236 is a reply to message #33057] Thu, 14 June 2007 08:28 Go to previous message
Thanks for the input.
"Benjamin Muskalla" <bmuskalla@innoopract.com> schrieb im Newsbeitrag
news:f4r1v8$kq$1@build.eclipse.org...
> Hi Markus,
> Cheers
> Benny
> Markus Kr
Previous Topic:Launching RAP on MAC OS X
Next Topic:RAP multilingual
Current Time: Sat Nov 08 06:56:58 EST 2025
Powered by FUDForum. Page generated in 1.04592 seconds
