validate constraints added to profile [message #22472] |
Wed, 09 May 2007 23:46  |
Originally posted by: asma.charfi.com
hi
I spcify some constraints in my profile (on stereotypes) and I want to
verify if the model which apply this profile respect these constraints
Ii installed emft (validation, transaction...) and tried to follow the
tutorial but it deals with adding constraints to metamodel and not to a
profile
how can I do ?
thank you for your help
Re: validate constraints added to profile [message #23541 is a reply to message #23198] |
Wed, 16 May 2007 09:26  |
Hi, Asma,
The "Show OCL Console" menu on the UML and Ecore model editors is new in the
OCL 1.1 M7 milestone.
It sounds like you are using OCL 1.0.x, from the reference to "EMFT OCL" in
the help documentation. In that case, you can open the Console view using
the "Window -> Show View..." menu. Then, pull down the "Open Console" menu
button in the console view's action bar and select the "Interactive OCL"
option to open the console in any editor context.
Christian
charfi asma wrote:
> hi,
> the "Show OCL Console" appear only in the model "extlibrary" using the
> org.eclipse.emf.ocl.examples.interpreter
> I tried to use this plugin to have my OCL console in the employee model
> but it did not work.
> how can I obtein the OCL console?
> in the OCL's Help "EMFT OCL Developer Guide->Tutorials->OCL interpreter
> Example, there was Query that we should create :
> "boolean valid;
> try {
> Query query = QueryFactory.eINSTANCE.createQuery(
> "self.books->collect(b : Book | b.category)->asSet()",
> LibraryPackage.eINSTANCE.getWriter());
> // record success
> valid = true;
> } catch (IllegalArgumentException e) {
> // record failure to parse
> valid = false;
> System.err.println(e.getLocalizedMessage());
> }" where did we should create this query (in witch file)?thank you in
> advanceasma"Christian W. Damus" <cdamus@ca.ibm.com> a �rit dans le message
> de news: f1t6fl$4cf$1@build.eclipse.org...
FUDForum. Page generated in 0.04853 seconds
