Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » RSE plugin integration with dltk
RSE plugin integration with dltk [message #22435] Tue, 22 April 2008 01:06 Go to next message
Hi all,
I'm developing an dltk based IDE for a custom scripting language using
dltk 1.0.
Earlier we have developed the IDE using eclipse base framework 3.3, in
which we have used default project wizard of eclipse. We then used the
remote system explorer (RSE) feature which added the drop down entry in
Project wizard for creating new project on remote system.
How to do the same with default project wizard provided by dltk 1.0.
Please help?
thanks and regards,
Abhijit.
Re: RSE plugin integration with dltk [message #22486 is a reply to message #22435] Tue, 22 April 2008 02:02 Go to previous messageGo to next message
Hi Abhijit,
Latest DLTK 1.0 provide feature named environments, and we have implementation of RSE environment for each existed
connection (except telnet, windows).
DLTK Project wizards allow selection of connection or host on which project will be created.
So if RSE and RSE intergarion plugins are available, it will work almost same as default project wizard with RSE.
Andrei Sobolev.
> Hi all,
> dltk 1.0.
> Please help?
> thanks and regards,
> Abhijit.
Re: RSE plugin integration with dltk [message #24397 is a reply to message #22486] Thu, 29 May 2008 02:05 Go to previous messageGo to next message
Thanks for the help.
We now had eclipse 3.4M7/3.4RC2 installed with dltk1.0RC1 and required
dltkrse plugin. Also we have RSE3.0RC1 intalled.
But now we are getting "org.eclipse.swt.SWTException: Invalid Thread
Access" whenever we try to open our script in editor. We also tried
creating a ruby script and opened it. Still we get
"org.eclipse.swt.SWTException: Invalid Thread Acess" exception.
We observed that if we donot install RSE3.0RC1, our product works fine.
Should I raise this as a bug in eclipse 3.4M7/3.4RC2 or in RSE3.0RC1?
Please help.
regards,
Abhijit.
Re: RSE plugin integration with dltk [message #24477 is a reply to message #24397] Thu, 29 May 2008 03:14 Go to previous messageGo to next message
Hi Abhijit,
There is already bug for this in RSE https://bugs.eclipse.org/bugs/show_bug.cgi?id=227750
This is caused by early initialization of RSE.
For a workaround please try to start Eclipse with -clean argument.
Andrei Sobolev.
> Please help.
> regards,
> Abhijit.
Re: RSE plugin integration with dltk [message #24599 is a reply to message #24477] Thu, 29 May 2008 14:17 Go to previous messageGo to next message
Problem shall be fixed in DLTK 0.95RC2. Note: we downgraded version
number from 1.0 to 0.95 since we're still incubating project.
> Hi Abhijit,
> Best regards,
> Andrei Sobolev.
>> Please help.
>> regards,
>> Abhijit.
Re: RSE plugin integration with dltk [message #24862 is a reply to message #24599] Tue, 03 June 2008 07:36 Go to previous message
Hi Andrey,
The RSE is working fine in new 0.95RC2 version. Thanks for the help.
regards,
Abhijit.
Previous Topic:Reconiling strategy problem in dltk1.0RC1
Next Topic:Ruby module in DLTK
Current Time: Fri Nov 07 00:11:38 EST 2025
Powered by FUDForum. Page generated in 0.04088 seconds
