| GMF Tutorial , Dashboard [message #228525] |
Thu, 30 April 2009 10:02  |
hi guys i am working in GMF in 15 min Tutorial :
http://www.ibm.com/developerworks/opensource/library/os-ecl- gmf/
and have few Problems:
first i downloaded the example of the Tutorialpage at the end , but i dont
know how to make it run !!!
seconde in the tutorial there was written if i want to enter the dashboard
i have to go :
Window > Show View > Other > GMF Dashboard
i tried this but after
Window > Show View > Other i find No GMF Dashboard :(
i downloaded gmf-sdk-2.1.3 unzipped it and put the files in the proper
ecliupse File , i have GEF running from a time and it works , and i have
EMF too ...
what can be the problem ?
somebody have a src example that he can send me , just to see if it is
working
here is my email address elia-work@gmx.de
i will really appreciate any help because i am having really problems here.
thanks a lot
Elia
| Re: GMF Tutorial , Dashboard [message #228773 is a reply to message #228525] |
Mon, 04 May 2009 11:25  |
Hi Elia,
the tutorial you are using is quite old, so things may have changed. I
would suggest using the tutorial at
http://wiki.eclipse.org/index.php/GMF_Tutorial instead.
Example code for this tutorial is available via CVS:
:pserver:anonymous@dev.eclipse.org:/cvsroot/modeling
and from there the following projects:
org.eclipse.gmf/examples/org.eclipse.gmf.examples.mindmap.*
And to make your life easier, you could download and use the integrated
"Eclipse Modeling Tools" package from http://www.eclipse.org/downloads/.
It has EMF, GMF and all dependencies already installed.
HTH,
Marco
> dont know how to make it run !!!
> dashboard i have to go :
> i tried this but after Window > Show View > Other i find No GMF
> Dashboard :(
> EMF too ...
> working
> thanks a lot
> Elia
FUDForum. Page generated in 0.05298 seconds
