Home » Eclipse Projects » GEF » Performance Problem
Performance Problem [message #214030] Wed, 12 April 2006 10:24 Go to next message
Originally posted by: Albrecht-web.arcor.de
I have a medium performance problem. My Gef-Editor loads a File with about
3000 nodes and again about 3000 connections between these nodes. The
Editor needs a long time to render or display the diagram. When zooming
the diagram it takes also a long time to display the new diagram.
There is also a Gef TreeViewer coupled to the Editor. When clicking a node
somewhere down the Editor synchronise an checks the same node. But the
Editor-Pane scrolls ans scrolls like a slideshow.
I don't know how to improve the performance. Any hints? I' pleased to all
replys.
Albrecht
Re: Performance Problem [message #214089 is a reply to message #214030] Wed, 12 April 2006 14:05 Go to previous messageGo to next message
Have you enabled antialiasing?
"Albrecht" <Albrecht-web@arcor.de> wrote in message
news:498c41c4f3f015d538482115e43e7b02$1@www.eclipse.org...
> replys.
> Albrecht
Re: Performance Problem [message #214146 is a reply to message #214089] Thu, 13 April 2006 01:59 Go to previous messageGo to next message
No, because several Win2000 Workstation do not support this. A 4000 Nodes
Diagram takes 2-3 Minutes until displayed.
>> replys.
>> Thanks,
>> Albrecht
Re: Performance Problem [message #214170 is a reply to message #214030] Thu, 13 April 2006 14:57 Go to previous messageGo to next message
Perhaps you are using the shortestpathconnectionrouter? When zooming, the
connections think that the anchor has moved, and every connection in your
diagram is re-routed. The logic example is optimized to ignore this type of
coordinate event.
> replys.
> Albrecht
Re: Performance Problem [message #214357 is a reply to message #214170] Mon, 17 April 2006 02:41 Go to previous message
You are right... I'm using the Shortpathrouter. As soon as possible I will
inspect the Logic Examble and report my outcomes. Thanks so far.
> coordinate event.
>> replys.
>> Thanks,
>> Albrecht
Previous Topic:How to create a second IEditorInput
Next Topic:menu in draw2d ??
Current Time: Sun Nov 09 04:23:31 EST 2025
Powered by FUDForum. Page generated in 0.04350 seconds
