Home » Newcomers » Newcomers » Problem Reading Cheat Sheet instructions
Problem Reading Cheat Sheet instructions [message #213229] Thu, 31 May 2007 21:51 Go to next message
I am running version 3.2.
The problem applies to all cheat sheets I have tried but the current one I
am looking at is from the welcome screen, Creating an Eclipse Plugin. In
the step Modify the plug-in there is the following instruction
To modify your com.example.helloworld plug-in, perform the following
steps:
The problem is that there are no steps displayed after the colon in the
shaded area.
Re: Problem Reading Cheat Sheet instructions [message #213254 is a reply to message #213229] Fri, 01 June 2007 02:54 Go to previous messageGo to next message
Originally posted by: newsgroups.pellaton.li
This is a known issue in Eclipse 3.2: Cheat sheets are composed of so
called 'items' and 'subitems'. For some reason, the subitems are only
displayed if all the previous items are marked as 'done'.
So, to see the subitems, run through the cheat sheet and mark every
step as 'done'. When you arrive at the point you mentioned, all
subitems should become visible.
AFAIK this is solved in the upcoming 3.3 release...
HTH
Michael
> steps:
> shaded area.
Re: Problem Reading Cheat Sheet instructions [message #213349 is a reply to message #213254] Fri, 01 June 2007 12:54 Go to previous message
Michael Pellaton wrote:
> Hi
Yes. I tried this in Eclipse 3.3.0 and it appears to work correctly. I
could see all of the cheat sheet just by scolling down. Mark Dexter
> HTH
> Michael
>> steps:
>> shaded area.
Previous Topic:Learning JAVA using Eclipse
Next Topic:loading a class or a .jar during runtime
Current Time: Wed Sep 17 07:21:04 EDT 2025
Powered by FUDForum. Page generated in 0.09719 seconds
