Home » Language IDEs » C / C++ IDE (CDT) » Add directory to PATH environment variable, globally and programmatically(PATH environment variable)
Add directory to PATH environment variable, globally and programmatically [message #1278740] Thu, 27 March 2014 15:47 Go to next message
Can anyone tell me the best way to add a directory to the global system PATH environment programmatically, either in java or statically, perhaps in plugin_customization.ini?
(See attached source)
I have used this to append the environment
UserDefinedEnvironmentSupplier udes = EnvironmentVariableManager.fUserSupplier
but I don't think its the right approach. Once set changes to the underlying environment set outside Eclipse don't get reflected when you restart with the same workspace. I just want something to append my PATH version to the global, system PATH version.
Any suggestions appreciated.
cheers john
Re: Add directory to PATH environment variable, globally and programmatically [message #1282580 is a reply to message #1278740] Wed, 02 April 2014 10:25 Go to previous messageGo to next message
I solved this. In case anyone is wondering this is my solution:
    import org.eclipse.cdt.core.envvar.IEnvironmentVariable;
    import org.eclipse.cdt.internal.core.envvar.EnvironmentVariableManager;
    import org.eclipse.cdt.internal.core.envvar.UserDefinedEnvironmentSupplier;
    import org.eclipse.cdt.managedbuilder.envvar.IBuildEnvironmentVariable;
       * Add a path to the beginning of the PATH environment variable.
       * This path is not persisted so its ok to perform this on every
       * startup. The existing system PATH is maintained.
       * Note:
       * 1) the PATH modification does not appear in Environment preference page
       * (Window > Preferences > C/C++ > Build > Environment)! Rather it appears
       * in every project property >  C/C++ Build > Environment > PATH variable.
       * 2) each call to this method overwrites previous values in PATH. If multiple
       * paths are to be prepended they should be concatenated in a single call.
       * @param path The directory or directories to prepend, separated with the
       * relevant path delimiter.
      public  static void prependToSystemPath(String path) {
        EnvironmentVariableManager.fUserSupplier.createOverrideVariable("PATH", path,
            IBuildEnvironmentVariable.ENVVAR_PREPEND,
            EnvironmentVariableManager.getDefault().getDefaultDelimiter());
and I use it thus:
      prependToSystemPath("c:\mypath1;c:\mypath2");
The benefit is this code can be called everytime Eclipse starts (I use <extension point="org.eclipse.ui.startup">) and each time it will prepend my path to whatever system path is defined at that time. This means, for example, you can use a workspace on Windows during one Eclipse session and then subsequently use the same workspace on a Linux system and the system path is reset for each start.
Re: Add directory to PATH environment variable, globally and programmatically [message #1283379 is a reply to message #1282580] Thu, 03 April 2014 06:55 Go to previous message
i use a batch file (on Windows), works like a charm.
@echo off
PATH=C:\mingw64\bin;%PATH%
start eclipse.exe
One can use different batches to select different compiler paths if needed.
regards,
Klaus
Previous Topic:running CDT indexer from commandline
Next Topic:"Add include" does not work
Current Time: Sun Sep 07 23:49:21 EDT 2025
Powered by FUDForum. Page generated in 0.07195 seconds
