Home » Eclipse Projects » Eclipse Platform » Help System Indexing Question
Help System Indexing Question [message #212850] Thu, 18 March 2004 08:20 Go to next message
Originally posted by: swoolley.hursley.ibm.com
Whilst performing a search in the help system of my runtime workbench
(V2.1.2), I noticed a few messages being written to the console in my
development workbench (also V2.1.2). They looked like this (copied directly
form the console):
Parse Aborted: Encountered "<EOF>" at line 67, column 7534.
Was expecting:
<CloseQuote2> ...
Parse Aborted: Encountered "<EOF>" at line 31, column 1932.
Was expecting one of:
<ArgName> ...
<TagEnd> ...
Parse Aborted: Encountered "<EOF>" at line 37, column 1524.
Was expecting:
<CloseQuote2> ...
I have identified the doc plug-in that is causing these errors, but am
unable to narrow it down to the file(s) that are causing these errors to be
thrown.
Any help gratefully received!
Best wishes,
Steve
Re: Help System Indexing Question [message #213263 is a reply to message #212850] Thu, 18 March 2004 22:44 Go to previous messageGo to next message
You have several options;
1. If you have access, use chkpii tool.
2. In PDE launch configuration, enable tracing and set
org.eclipse.help/debug/search property to true. It will list every file
being indexed.
3. Copy eclipse\plugins\org.eclipse.help_2.1.2\.options to
eclipse\directory. and set value org.eclipse.help/debug/search to true.
Launch eclipse with "-debug" switch.
4. Import org.apache.lucene plug-in, put a break-point in
org.apache.lucene.demo.html.ParseException.
Konrad
"Stephen Woolley" <swoolley@hursley.ibm.com> wrote in message
news:c3c7g3$bvk$1@eclipse.org...
directly
> form the console):
> Was expecting:
> <CloseQuote2> ...
> <ArgName> ...
> <TagEnd> ...
> Was expecting:
> <CloseQuote2> ...
be
> thrown.
> Best wishes,
> Steve
Re: Help System Indexing Question [message #213583 is a reply to message #213263] Fri, 19 March 2004 11:20 Go to previous message
Also, try running HTMLTidy (http://tidy.sf.net) against the (X)HTML in
your plugin. It'll quickly tell you where you've got DTD errors in your
HTML files.
Dan
> being indexed.
> Konrad
>>Hi,
> directly
>>form the console):
>>Was expecting:
>> <CloseQuote2> ...
>> <ArgName> ...
>> <TagEnd> ...
>>Was expecting:
>> <CloseQuote2> ...
> be
>>thrown.
>>Best wishes,
>>Steve
Previous Topic:Report Designer
Next Topic:Version 3 I20040318 - Workspace chooser - how do I turn it off?
Current Time: Sat Nov 08 14:05:25 EST 2025
Powered by FUDForum. Page generated in 0.03568 seconds
