Home » Newcomers » Newcomers » Filtering in CDT 4.0??
Filtering in CDT 4.0?? [message #211455] Mon, 21 May 2007 06:00 Go to next message
Originally posted by: ggg.sdf.com
I seems that the filtering functionality is left out of the new CDT 4.0.
Does anyone know if its possible to filter out files like *.pdf, *.tex
etc?
Re: Filtering in CDT 4.0?? [message #211715 is a reply to message #211455] Wed, 23 May 2007 03:19 Go to previous messageGo to next message
> etc?
If you want to filter such a files in explorer there is an 'Name filter
patterns'
best regards
bartek michalik
Re: Filtering in CDT 4.0?? [message #211767 is a reply to message #211715] Wed, 23 May 2007 11:09 Go to previous messageGo to next message
Bartosz Michalik wrote:
>> 4.0. Does anyone know if its possible to filter out files like *.pdf,
>> *.tex etc?
> patterns'
> best regards
> bartek michalik
Where is 'Name filter patterns'? I have made a standard C++ project in
CDT 4.0 and in the Project Explorer I cannot find anything called 'Name
filter patterns'.
If I make a Java project instead there is something called 'Name filter
patterns' in the Package explorer. But my question was in regard to a
C++ project in CDT 4.0 which does not seem to have this option.
Re: Filtering in CDT 4.0?? [message #211835 is a reply to message #211767] Wed, 23 May 2007 15:51 Go to previous messageGo to next message
view "C/C++ projects" menu arrow (on the right) -> Filters ...
then first option in the window
Re: Filtering in CDT 4.0?? [message #211843 is a reply to message #211835] Wed, 23 May 2007 16:05 Go to previous messageGo to next message
That is not possible in CDT 4.0. When I click the downward arrow (menu)
in Project Explorer I get:
Top Level Elements
Select Working Set...
// Deselect Working Set...
//Edit Active Working Set
Package Presentation
Customize View...
Link Editor
If I choose Customize View I can filter various pre-specified extensions
and objects, but I cannot make my own definitions.
Are you sure you are not using CDT 3.1.2 I seem to remember that it
worked like you describe in that version.
Re: Filtering in CDT 4.0?? [message #211879 is a reply to message #211843] Thu, 24 May 2007 07:46 Go to previous messageGo to next message
Version: 4.0.0.200705111955
Build id: 200705111955
best regards
bartek michalik
Re: Filtering in CDT 4.0?? [message #211917 is a reply to message #211879] Thu, 24 May 2007 10:05 Go to previous message
> best regards
> bartek michalik
hm it seems that the default "Project Explorer" does not have the option
but if I choose to view "C/C++ Projects" instead I get the possibility
to edit filters...Wierd that it does not choose this kind of Explorer
when creating a new C++ project.
Previous Topic:Code conversion
Next Topic:How to update plug-in description
Current Time: Tue Oct 28 01:26:04 EDT 2025
Powered by FUDForum. Page generated in 0.09909 seconds
