JInternalFrame visibility [message #20243] |
Sun, 22 February 2004 03:11  |
Originally posted by: appel__.hotmail.com
I'm using Eclipse M7 with VE-runtime-I20040219.
When adding an JInternalFrame to a JDesktopPane the propertypane for the
internal frame says its visible property is set to true. But it's not.
I think it says in the javadoc for JInternalFrame that one must explicitly
setVisible(true) and that code isn't generated automatically. I had to
first set visible to false, and then true for the correct code to be
generated.
Is this a bug or am I doing something wrong?
/Johan Appelgren
Re: JInternalFrame visibility [message #20639 is a reply to message #20247] |
Mon, 23 February 2004 16:07  |
On Mon, 23 Feb 2004 09:21:50 -0500, Rich Kulp wrote:
> For a JInternalFrame, we hide the visible property. For a JInternalFrame
> you are supposed to use the show/hide methods, not the visible property.
> (I think you may be thinking of the old AWT Frame, you used to use set
> visible, but show()/hide() are the expected methods to do this now even
> for frame).
Yes, you are right.
Thanks.
Re: JInternalFrame visibility [message #582250 is a reply to message #20243] |
Mon, 23 February 2004 09:21  |
for frame).
I think you may have the contentpane of the internal frame selected
instead of the internal frame itself. The content pane has the visible
property, and it is defaulted to true for it.
Thanks, Rich Kulp
Re: JInternalFrame visibility [message #582274 is a reply to message #20247] |
> for frame).
Yes, you are right.
Thanks.
FUDForum. Page generated in 0.06108 seconds
