Home » Eclipse Projects » GEF » Painting a figure of a connection
Painting a figure of a connection [message #208751] Wed, 08 February 2006 06:46 Go to next message
--------------030404020701040306020002
in a previous post I ask how I can modify the appearance of a
polylineconnection.
(news://news.eclipse.org:119/drtapa$s61$1@utils.eclipse.org)
In my current solution I override the paintFigure() method. Is this ok?
But unfortunately I have a problem. I draw a rectangle with a pointlist
and I try to fill it. But then it only fills the right/top half of my
connectionfigure? Why? Is it a problem with the Bounds of my figure?
I also have try to paint my figure with the graphics object and the draw
methods. But then all painting also appears only in one half of my figure.
Have somebody a hint for a solution?
I have attached a picture of my figure and here my mentioned code:
public void paintFigure(Graphics graphics) {
int width = 10;
Point start = getStart();
Point end = getEnd();
PointList points = new PointList();
points.addPoint(start);
points.addPoint(start.getTranslated(-width/2,0));
points.addPoint(start.getTranslated(+width/2,0));
points.addPoint(end.getTranslated(+width/2,0));
points.addPoint(end.getTranslated(-width/2,0));
points.addPoint(end);
setPoints(points);
graphics.setBackgroundColor(ColorConstants.blue);
graphics.fillPolygon(points);
super.paintFigure(graphics);
Content-Type: image/gif;
name="connection.GIF"
Content-Disposition: inline;
filename="connection.GIF"
R0lGODlhJABiAPcAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAAAkAGIAAAj/ AP8JHEiwIAoU
BRMqXLjwIMOHECNKnEixYkKHFitizDhxI8eGB0OKRPiRIMl/KFqoVHmyJMqB KVe2aFmypcyZ
LmESvEnz48mYK3ty/Mkzp0CiMoVmRBrU6MujRY0yZenUZtKqO69KhRk151Sc W6Fq9cp1rMuv
Si2ixTqw69msTcOidFuzbFyyYu++zUtVLtC+eOeardt2sE+4gPcK1kt4ceLG f8EGjpxWo93H
h/lKVvyPbmaBnode3gw59NLRlSmu9WtaLWq2oA2LLsz4M2XYt1nLPq05dcfX umvPji2cN3HM
w3NPbm25N27mqoEv3+2aNvKlI0c6Nen7bPea332GIx86Hvv28+irlle7Pr37 9/Djy59Pv779
+/jz69/Pv79//wEBADs=
--------------030404020701040306020002--
Re: Painting a figure of a connection [message #208917 is a reply to message #208751] Thu, 09 February 2006 15:14 Go to previous messageGo to next message
Since you are expanding the area you are painting, the clip region is
probably cutting it off. The clip region is set to the bounding box of the
figure before the paint routine.
I'd recommend you reconsider and use the PolylineDecoration instead. To
change the points, there is an api PolylineDecoration#setTemplate. Then it
is a simple matter of setting this decoration on the target or source of
your PolylineConnection class.
i.e. in the createFigure for your editpart:
PointList points = ...
PolylineConnection conn = new PolylineConnection();
PolylineDecoration td= new PolylineDecoration();
td.setTemplate(points);
conn.setTargetDecoration(td);
-Steve
"Jens" <jens.bartelheimer@gmx.de> wrote in message
news:dsclnb$8vb$1@utils.eclipse.org...
> polylineconnection.
> int width = 10;
> setPoints(points);
Re: some general questions [message #209005 is a reply to message #208917] Fri, 10 February 2006 06:04 Go to previous messageGo to next message
Thanks Steve.
I have solved my problem with a MidpointLocator.
But I have got some general questions.
Is it right to initialize the figure in the constructor and then set the
size, ... in the paintFigure method depending on the getBounds() result?
And am I right that getBounds() returns the area where I can draw figures?
Is it possible to modify this area with the setBounds() method or should
I avoid this way?
public class ActivationBarFigure extends MyIndirectConnectionFigure {
RectangleFigure bar = new RectangleFigure();
final int width = 10;
public ActivationBarFigure() {
add(bar,new MidpointLocator(this,0));
//Set the height of the bar
Rectangle r = getBounds().getCopy();
bar.setSize(width,r.height);
Jens
> -Steve
>> polylineconnection.
>> int width = 10;
>> setPoints(points);
Re: some general questions [message #209055 is a reply to message #209005] Fri, 10 February 2006 10:53 Go to previous message
draw2d works in two steps. The first step is validation, which lays out
everything, and sets the bounds. The second step is painting. You should not
change the bounds during painting, since that will cause a repaint
(potentially infinite).
news:dshs0e$3bp$1@utils.eclipse.org...
> Thanks Steve.
> Is it possible to modify this area with the setBounds() method or should I
> avoid this way?
> Jens
>> the
>> it
>> -Steve
>>> Hi,
>>> polylineconnection.
>>> figure.
>>> int width = 10;
>>> setPoints(points);
Previous Topic:Composite edit parts and figure hierarchy
Next Topic:Re: Will antialiasing API appear on IFigure?
Current Time: Thu Nov 06 19:09:04 EST 2025
Powered by FUDForum. Page generated in 0.05737 seconds
