Home » Modeling » GMF (Graphical Modeling Framework) » how to parser XML file with GMF
how to parser XML file with GMF [message #208737] Wed, 15 October 2008 08:18 Go to next message
I have a diagram on the editor. I have done this diagram with GMF and
together
it, there is the same file in XML format associated.
I must parse with file XML, because i must extract the date.
What should i do?
very Thanks to all
Matteo
Re: how to parser XML file with GMF [message #208752 is a reply to message #208737] Wed, 15 October 2008 10:22 Go to previous messageGo to next message
excume
..."i must parse THIS file Xml"...
Re: how to parser XML file with GMF [message #212908 is a reply to message #208752] Sun, 07 December 2008 17:53 Go to previous message
Take a look at your xxx.test generated plugin (right click your model at
..genmodel files and select Generate All) there are some specific
utilities to parse the xml files manipulated by both GMF and EMF.
cheers
Matteo Monaco escreveu:
> excume
Previous Topic:How can i change the link connection in a compartement without changing the source?
Next Topic:How does code generation and custom code co-exist in a normal project?
Current Time: Fri Nov 07 00:53:27 EST 2025
Powered by FUDForum. Page generated in 0.04059 seconds
