Home » Language IDEs » ServerTools (WTP) » Bug in stopping JBoss?
Bug in stopping JBoss? [message #206440] Mon, 07 January 2008 03:41 Go to next message
Originally posted by: obdennis2007.hotmail.com
The configuration for server includes a JNDI port number. I have setup two
server configs for JBoss 4 in Eclipse web server tool.
Each of these JBoss server are configured to be able to run at the same
time (i.e. all conflicting ports resolved). They both starts and run fine
in Eclipse. One server is using jndi port 1099 and the other using 11099.
When stopping the one that is 11099, Eclipse reports error:
Exception in thread "main" javax.naming.CommunicationException: Could not
obtain connection to any of these urls: localhost:1099 [Root exception is
javax.naming.CommunicationException: Failed to connect to server
javax.naming.ServiceUnavailableException: Failed to connect to server
localhost:1099 [Root exception is java.net.ConnectException: Connection
refused: connect]]]
at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java :1416)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:5 96)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:5 89)
at javax.naming.InitialContext.lookup(Unknown Source)
at org.jboss.Shutdown.main(Shutdown.java:214)
This is so when the other (normal standard config server with port 1099)
server is stopped. If that other one is running, stopping the one with
11099 port will stop the 1099 one..
This leads me think that Eclipse is not using the configured 11099 (or
any) in the server config to stop it. It will going to use 1099 (hard
coded somewhere) regardless of the setting made in the server config. I
have verified the xml file in the workspace it is set as 11099 for that
server which failed to stop from Eclipse. Can anyone confirm this?
Thanks in advance.
Re: Bug in stopping JBoss? [message #489388 is a reply to message #206440] Fri, 02 October 2009 14:45 Go to previous messageGo to next message
I can verify in my installation that I have the same problem. The JBoss server connectors ignore the jndi port on shutdown.
Eclipse 3.3.2
WebStandardTools 1.0.2.v200706120315
JDK 1.6.05
Other people seem to have this problem as well:
http://stackoverflow.com/questions/173487/problems-with-shut ting-down-jboss-in-eclipse-if-i-change-jndi-port
[Updated on: Fri, 02 October 2009 15:00] by Moderator
Re: Bug in stopping JBoss? [message #489439 is a reply to message #489388] Fri, 02 October 2009 21:47 Go to previous messageGo to next message
Here is a detailed fix for this problem:
The Eclipse WTP server connector won't shut down JBoss when the jndi port is remapped.
This is because the default server connector profiles don't use their own alias for the jndiPort. This problem is also discussed at stackoverflow.com:
The solution comes from the .serverdef files in eclipse:
<eclipse> \plugins\org.eclipse.jst.server.generic.jboss_1.5.105.v20070 9061325\servers\jboss*.serverdef
They declare an xml property for the jndi port:
<property id="jndiPort"
label="%jndiPort"
type="string"
context="server"
default="1099" />
This simply needs to be used where the serverdef has the STOP command coded:
So this:
<stop>
<mainClass>org.jboss.Shutdown</mainClass>
<workingDirectory>${serverRootDirectory}/bin</workingDirectory >
<programArguments>-S</programArguments>
<vmParameters></vmParameters>
<classpathReference>jboss</classpathReference>
</stop>
becomes this:
<stop>
<programArguments>-s jnp://${serverAddress}:${jndiPort}</programArguments>
</stop>
The philosophy for this can be verified by comparison to the definition for the jndi connection:
<jndiConnection>
<providerUrl>jnp://${serverAddress}:${jndiPort}</providerUrl>
<initialContextFactory>org.jnp.interfaces.NamingContextFactory </initialContextFactory>
<jndiProperty>
<name></name>
<value></value>
</jndiProperty>
</jndiConnection>
Credit for the inspiration for this general case fix goes to: Moisa Laurentiu Florin. It was their contribution that got me to look for a way of substituting in the ${jndiPort} instead of a hard coded value.
Re: Bug in stopping JBoss? [message #509199 is a reply to message #206440] Thu, 21 January 2010 11:29 Go to previous messageGo to next message
just for the records: I created a modified JBoss plugin and added this "stop" parameters: http://www.cs.hs-rm.de/~knauf/public/
Best regards
Wolfgang
Re: Bug in stopping JBoss? [message #539546 is a reply to message #489439] Fri, 11 June 2010 04:52 Go to previous message
this was changed in JBoss 6.0.0M3.
The stop command is now:
"- s service:jmx:rmi:///jndi/rmi://localhost:1090/jmxrmi"
Not that the port also changed: it is no longer the JNDI port at 1099, but
RMI/JMX port 1090. So, you will need another config parameter in the server
definition.
More details: https://community.jboss.org/thread/152911 (more links in this
forum thread)
I don't know whether the "JNDI port" parameter is required at all for JBoss
6.0.0M3 servers.
My eclipse plugin at http://www.cs.hs-rm.de/~knauf/public/ contains a server
definition for 6.0.0M3 which contains this change.
Wolfgang
Previous Topic:Tomcat in Eclipse, Error 500 ClassNotFound for servlet
Next Topic:web-fragment.xml causes nested jar on deployment
Current Time: Fri Nov 07 07:11:28 EST 2025
Powered by FUDForum. Page generated in 0.03632 seconds
