Home » Eclipse Projects » Eclipse Platform » Bug in compatibility feature of M7?
Bug in compatibility feature of M7? [message #204209] Mon, 01 March 2004 14:39 Go to next message
I've had people tell me that this might be a bug I need to file against
the Platform UI. Can someone tell me if this is a good idea?
I've heard a lot of different things in response to my questions about
porting my 2.1.2 plugins to 3.0 M7. I was wondering if someone could give
a rundown of exactly what my best approaches would be. Here's the
situation:
My plugins do import the org.eclipse.ui file and use some of the changed
parts. Should I change my plugin to include the import of
org.eclipse.ui.ide? Also, right now the error I get with my plugin is
this:
The selected wizard could not be started.
Reason:
Plug-in com.ibm.ws.build.plugin was unable to load class
com.ibm.ws.build.plugin.create.PluginImportWizard
Also, with M7 do I need to include org.eclipse.core.runtime.compatibility
or should it do that for me when it detects that my plugin are 2.x plugins?
In addition, if someone could explain to me how I could check to see if my
plug-in references the internals of some of the changing API's. I just
need a guideline of what to look for in my code, but I think that my
program does not do this.
Thank you so much for all the help,
Jeremiah Richardson
Below is a copy of the dependencies in my plugin.xml and the .log file
created from the error:
plugin.xml dependecies:
<requires>
<import plugin="com.ibm.ws.build.wsant" version="5.0.0"
match="compatible"/>
<import plugin="org.apache.xerces"/>
<import plugin="org.eclipse.core.resources"/>
<import plugin="org.eclipse.ui"/>
<import plugin="org.eclipse.swt"/>
<import plugin="org.eclipse.debug.core"/>
<import plugin="org.eclipse.debug.ui"/>
<import plugin="org.eclipse.jdt.launching"/>
<import plugin="org.eclipse.jdt.core"/>
<import plugin="org.eclipse.ui.externaltools"/>
</requires>
log file:
!ENTRY org.eclipse.core.runtime 4 2 Feb 23, 2004 22:38:35.53
!MESSAGE Attempt to activate a disabled plug-in: "com.ibm.ws.build.plugin".
!ENTRY org.eclipse.core.runtime 4 1 Feb 23, 2004 22:38:35.53
!MESSAGE Plug-in com.ibm.ws.build.plugin was unable to load class
com.ibm.ws.build.plugin.create.PluginImportWizard.
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.star t()
org.eclipse.osgi.framework.internal.core.BundleContext.start Activator(BundleContext.java:1071)
org.eclipse.osgi.framework.internal.core.BundleContext.start (BundleContext.java:991)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:403)
at org.eclipse.osgi.framework.internal.core.Bundle.start(Bundle .java:312)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:133)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:125)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:114)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:171)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:168)
org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.creat eExecutableExtension(WorkbenchWizardElement.java:96)
org.eclipse.ui.internal.dialogs.ImportWizard$1.createWizard( ImportWizard.java:60)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(Wo rkbenchWizardNode.java:133)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:819)
at org.eclipse.core.runtime.Platform.run(Platform.java:493)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(Wo rkbenchWizardNode.java:114)
org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizar d(WorkbenchWizardNode.java:112)
org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(Wiz ardSelectionPage.java:96)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:677)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:316)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:402)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2029)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:647 )
at org.eclipse.jface.window.Window.open(Window.java:627)
org.eclipse.ui.actions.ImportResourcesAction.run(ImportResou rcesAction.java:149)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:536)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:420)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Nested exception:
org.eclipse.core.runtime.CoreException: Attempt to activate a disabled
org.eclipse.core.internal.plugins.PluginDescriptor.throwExce ption(PluginDescriptor.java:379)
org.eclipse.core.internal.plugins.PluginDescriptor.pluginAct ivationEnter(PluginDescriptor.java:357)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:436)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:406)
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivator.java:48)
org.eclipse.osgi.framework.internal.core.BundleContext$1.run (BundleContext.java:1054)
org.eclipse.osgi.framework.internal.core.BundleContext.start Activator(BundleContext.java:1050)
Re: Bug in compatibility feature of M7? [message #204327 is a reply to message #204209] Mon, 01 March 2004 16:57 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
if you have the processing directive
<?eclipse version="3.0"?>
at the top of your plugin.xml then you need to require the things that you
need. There are no freebies and substitutions done for you. That means
that in your case you likely need
org.eclipse.ui.ide
org.eclipse.ui.... <some UI folks can fill in the rest perhaps>
Looking or references to internals. Basically look to see if you reference
any packages which have "internal" in the pacakage name (e.g.,
org.eclise.core.internal.runtime is not good for you to reference)
Jeff
"Jeremiah Richardson" <jerry_234@hotmail.com> wrote in message
news:c203i4$r9k$1@eclipse.org...
> situation:
> this:
> Reason:
plugins?
> Jeremiah Richardson
> <requires>
> </requires>
> log file:
> !STACK 0
> at
Context.java:1071)
> at
ava:991)
> at
ava:403)
> at
> at
> at
> at
:168)
> at
> at
a:60)
> at
e.java:133)
> at
:819)
> at
e.java:114)
> at
dNode.java:112)
> at
..java:96)
> at
> at
> at
> at
149)
> at
> at
tem.java:488)
> at
tionItem.java:420)
> at
> at
java:257)
> at
> at
> at
..java:25)
> Nested exception:
> at
riptor.java:379)
> at
> at
> at
r.java:406)
> at
r.java:48)
> at
ava:1054)
> at java.security.AccessController.doPrivileged(Native Method)
> at
Context.java:1050)
> at
ava:991)
> at
ava:403)
> at
> at
> at
> at
:168)
> at
> at
a:60)
> at
e.java:133)
> at
:819)
> at
e.java:114)
> at
dNode.java:112)
> at
..java:96)
> at
> at
> at
> at
149)
> at
> at
tem.java:488)
> at
tionItem.java:420)
> at
> at
java:257)
> at
> at
> at
..java:25)
Re: Bug in compatibility feature of M7? [message #204655 is a reply to message #204327] Tue, 02 March 2004 13:36 Go to previous messageGo to next message
I do not have the version tags in my plugin.xml's. I thought I was
supposed to leave them out so that M7 could detect them as legacy and add
it in for me? Any other ideas of what I should do?
> org.eclipse.ui.ide
> Jeff
> > situation:
> > this:
> > Reason:
> plugins?
> > Jeremiah Richardson
> > <requires>
> > </requires>
> > log file:
> > !STACK 0
> > at
> Context.java:1071)
> > at
> ava:991)
> > at
> ava:403)
> > at
> > at
> > at
> > at
> :168)
> > at
> > at
> a:60)
> > at
> e.java:133)
> > at
> :819)
> > at
> e.java:114)
> > at
> dNode.java:112)
> > at
> ..java:96)
> > at
> > at
> > at
> > at
> 149)
> > at
> > at
> tem.java:488)
> > at
> tionItem.java:420)
> > at
> > at
> java:257)
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> ..java:25)
> > Nested exception:
> > at
> riptor.java:379)
> > at
> > at
> > at
> r.java:406)
> > at
> r.java:48)
> > at
> ava:1054)
> > at
> Context.java:1050)
> > at
> ava:991)
> > at
> ava:403)
> > at
> > at
> > at
> > at
> :168)
> > at
> > at
> a:60)
> > at
> e.java:133)
> > at
> :819)
> > at
> e.java:114)
> > at
> dNode.java:112)
> > at
> ..java:96)
> > at
> > at
> > at
> > at
> 149)
> > at
> > at
> tem.java:488)
> > at
> tionItem.java:420)
> > at
> > at
> java:257)
> > at
> > at
> > at
> ..java:25)
Re: Bug in compatibility feature of M7? [message #204908 is a reply to message #204655] Tue, 02 March 2004 22:10 Go to previous messageGo to next message
Try running with -console -consolelog on the command line.
In the command window (shell on unix, dos box on windows) you should get an
"osgi>" prompt. In there type "ss". Taht will summarize all the plugins
you have installed. Find yours and remember the number. It will likely
show up as being in "INSTALLED" state. You want it to be either RESOLVED or
ACTIVE. Assuming it is not, type
diag <your bundle number>
That should tell you what constraints could be resolved. Follow that around
and see if you can see anything else that is unresolved.
Jeff
news:c22k85$opn$1@eclipse.org...
you
> > org.eclipse.ui.ide
reference
> > Jeff
against
give
> > > situation:
changed
> > > this:
> > > Reason:
> > plugins?
if my
just
> > > Jeremiah Richardson
> > > <requires>
> > > </requires>
> > > log file:
> > > !STACK 0
> > > at
> > Context.java:1071)
> > > at
> > ava:991)
> > > at
> > ava:403)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > :168)
> > > at
> > > at
> > a:60)
> > > at
> > e.java:133)
> > > at
> > :819)
> > > at
> > e.java:114)
> > > at
> > > at
> > dNode.java:112)
> > > at
> > ..java:96)
> > > at
> > > at
> > > at
> > > at
> > > at
> > 149)
> > > at
> > > at
> > tem.java:488)
> > > at
> > tionItem.java:420)
> > > at
> > > at
> > > at
> > > at
> > > at
> > java:257)
> > > at
> > > at
> > > at
> > ..java:25)
> > > Nested exception:
> > > at
> > riptor.java:379)
> > > at
> > > at
> > > at
> > r.java:406)
> > > at
> > r.java:48)
> > > at
> > ava:1054)
> > > at
> > Context.java:1050)
> > > at
> > ava:991)
> > > at
> > ava:403)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > :168)
> > > at
> > > at
> > a:60)
> > > at
> > e.java:133)
> > > at
> > :819)
> > > at
> > e.java:114)
> > > at
> > > at
> > dNode.java:112)
> > > at
> > ..java:96)
> > > at
> > > at
> > > at
> > > at
> > > at
> > 149)
> > > at
> > > at
> > tem.java:488)
> > > at
> > tionItem.java:420)
> > > at
> > > at
> > > at
> > > at
> > > at
> > java:257)
> > > at
> > > at
> > > at
> > ..java:25)
Re: Bug in compatibility feature of M7? [message #205223 is a reply to message #204908] Wed, 03 March 2004 09:00 Go to previous message
I tried this but all my plugins appeared in the resolved or active states
and yet I'm still getting the same error. Is there anything else I can
try to break down this problem some more?
Jeremiah Richardson
> Jeff
> you
> > > org.eclipse.ui.ide
> reference
> > > Jeff
> against
> give
> > > > situation:
> changed
> > > > this:
> > > > Reason:
> > > plugins?
> if my
> just
> > > > Jeremiah Richardson
> > > > <requires>
> > > > </requires>
> > > > log file:
> > > > !STACK 0
> > > > at
> > > Context.java:1071)
> > > > at
> > > ava:991)
> > > > at
> > > ava:403)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > :168)
> > > > at
> > > > at
> > > a:60)
> > > > at
> > > e.java:133)
> > > > at
> > > :819)
> > > > at
> > > e.java:114)
> > > > at
> > > > at
> > > dNode.java:112)
> > > > at
> > > ..java:96)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > 149)
> > > > at
> > > > at
> > > tem.java:488)
> > > > at
> > > tionItem.java:420)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > java:257)
> > > > at
> > > > at
> > > > at
> > > ..java:25)
> > > > Nested exception:
> > > > at
> > > riptor.java:379)
> > > > at
> > > > at
> > > > at
> > > r.java:406)
> > > > at
> > > r.java:48)
> > > > at
> > > ava:1054)
> > > > at
> > > Context.java:1050)
> > > > at
> > > ava:991)
> > > > at
> > > ava:403)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > :168)
> > > > at
> > > > at
> > > a:60)
> > > > at
> > > e.java:133)
> > > > at
> > > :819)
> > > > at
> > > e.java:114)
> > > > at
> > > > at
> > > dNode.java:112)
> > > > at
> > > ..java:96)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > 149)
> > > > at
> > > > at
> > > tem.java:488)
> > > > at
> > > tionItem.java:420)
> > > > at
> > > > at
> > > > at
> > > > at
> > > > at
> > > java:257)
> > > > at
> > > > at
> > > > at
> > > ..java:25)
Previous Topic:error starting 3M7 (I do have 1.4 VM)
Next Topic:utf-8
Current Time: Thu Nov 06 15:57:45 EST 2025
Powered by FUDForum. Page generated in 0.04580 seconds
