Home » Eclipse Projects » GEF » about selection action
| about selection action [message #203918] |
Tue, 29 November 2005 04:11  |
Originally posted by: XXX.cn.ibm.com
Hi, pals
what should i do if I want my selection actions to correctly update the
status(enable/disable) when
the selection changes. For example, at the begining, i selected node one,
and at the same time, action A
enabled. while in the GEF editor, i keep selecting node one, after serveral
second, the attribute of node one
updated by underlined something, and action A should be disable.
thx a lot.
| Re: about selection action [message #203941 is a reply to message #203918] |
Tue, 29 November 2005 05:32   |
Sounds like you need to hook a listener that listens to you model for
such changes and updates all selection actions if a property changed and
the element is currently selected.
Cu, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
| Re: about selection action [message #203966 is a reply to message #203918] |
Tue, 29 November 2005 08:55   |
Originally posted by: none.unknown.com
Look at LogicEditor#createActions(). Make sure you register your actions as
selection actions, and their update() method will be invoked whenever the
selection changes.
"Magic" <XXX@cn.ibm.com> wrote in message
news:dmh606$d0$1@news.eclipse.org...
> Hi, pals
serveral
> thx a lot.
| Re: about selection action [message #204059 is a reply to message #203941] |
Wed, 30 November 2005 00:47   |
Yes, maybe we have to do it in this way. :(
and w'r used to hope there will be a better way in GEF.
anyway, thx a lot.
"Gunnar Wagenknecht" <gunnar@wagenknecht.org>
??????:dmhao5$77v$2@news.eclipse.org...
>> serveral
> Cu, Gunnar
> Gunnar Wagenknecht
| Re: about selection action [message #204303 is a reply to message #204059] |
Thu, 01 December 2005 14:37  |
You should hook the action to the command stack. Whenever a command is
executed, undone, etc., refresh the action's enablement. And also keep it as
a selection listener too.
news:dmjedi$8ff$1@news.eclipse.org...
> anyway, thx a lot.
>>> one,
>>> serveral
>> Cu, Gunnar
>> Gunnar Wagenknecht
Current Time: Fri Oct 24 01:36:46 EDT 2025
Powered by FUDForum. Page generated in 0.26490 seconds
