Home » Language IDEs » C / C++ IDE (CDT) » MBS extension: build variable don't include header files
MBS extension: build variable don't include header files [message #201767] Mon, 17 September 2007 12:00 Go to next message
I use tools that generate source and header files. I want yo use the
extension capability of the MBS 4.0 to include these tools in my tool
chain. In order to manage dependency problems, I stored the generated
files in a build variable (buildVariable field of the Output Type).
However the header files are not included in the variables in the makefiles.
Is this a normal behavior of MBS?
best regards,
Gaetan MORICE
Re: MBS extension: build variable don't include header files [message #201814 is a reply to message #201767] Mon, 17 September 2007 17:48 Go to previous messageGo to next message
> makefiles.
> best regards,
> Gaetan MORICE
The headers are not built, so they are only used in dependency rules,
which you will find in the .d files.
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
Re: MBS extension: build variable don't include header files [message #202082 is a reply to message #201814] Tue, 25 September 2007 04:15 Go to previous message
>> makefiles.
>> best regards,
>> Gaetan MORICE
> Chris Recoskie
> IBM Toronto
I agree, but in the project I am working on, the header files are
generated from other files. As a consequence the first time they don't
exists and the command to generate .d files fails. That's why I want to
use build variables and a special task defined with the prebuildStep
option of the Configuration in order to force the header files
generation before the build and enable .d files generation.
Gaétan MORICE
Solutions & Technologies
ANYWARE TECHNOLOGIES
www.anyware-tech.com
Previous Topic:Path and Symbols - References
Next Topic:modify menu labels...
Current Time: Thu Nov 06 19:56:59 EST 2025
Powered by FUDForum. Page generated in 0.03187 seconds
