Home » Eclipse Projects » GEF » problem with Properties
problem with Properties [message #200797] Thu, 27 October 2005 10:48
Originally posted by: siegercn.cs.tu-berlin.de
hello,
i have a GEF & EMF application , i have follows exceptions infos. when i
click Proprties cursor in order to display the properties of an Node .
the problem happened only at eclipse 3.1 :
java.lang.ArrayIndexOutOfBoundsException: 2
org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf(PropertySheetViewer.java:1195)
org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf(PropertySheetViewer.java:1198)
org.eclipse.ui.views.properties.PropertySheetViewer.access$2 (PropertySheetViewer.java:1101)
org.eclipse.ui.views.properties.PropertySheetViewer$3.childE ntriesChanged(PropertySheetViewer.java:308)
org.eclipse.ui.views.properties.PropertySheetEntry.fireChild EntriesChanged(PropertySheetEntry.java:295)
org.eclipse.ui.views.properties.PropertySheetEntry.refreshCh ildEntries(PropertySheetEntry.java:559)
org.eclipse.ui.views.properties.PropertySheetEntry.refreshFr omRoot(PropertySheetEntry.java:574)
org.eclipse.ui.views.properties.PropertySheetEntry.refreshFr omRoot(PropertySheetEntry.java:576)
org.eclipse.ui.views.properties.PropertySheetEntry.setValue( PropertySheetEntry.java:703)
org.eclipse.ui.views.properties.PropertySheetEntry.applyEdit orValue(PropertySheetEntry.java:146)
org.eclipse.ui.views.properties.PropertySheetEntry$1.applyEd itorValue(PropertySheetEntry.java:106)
at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 04)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(Ce llEditor.java:302)
org.eclipse.jface.viewers.TextCellEditor.handleDefaultSelect ion(TextCellEditor.java:291)
org.eclipse.jface.viewers.TextCellEditor$1.widgetDefaultSele cted(TextCellEditor.java:147)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:97)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.pde.internal.runtime.logview.EventDetailsDialog. open(EventDetailsDialog.java:152)
org.eclipse.pde.internal.runtime.logview.EventDetailsDialogA ction.run(EventDetailsDialogAction.java:91)
org.eclipse.pde.internal.runtime.logview.LogView$12.doubleCl ick(LogView.java:336)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:720)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:718)
org.eclipse.jface.viewers.StructuredViewer.handleDoubleSelec t(StructuredViewer.java:950)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1057)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:219)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:216)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:275)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Previous Topic:Centering text in flowpage vertically
Next Topic:DropTargetListener version
Current Time: Wed Oct 29 11:32:48 EDT 2025
Powered by FUDForum. Page generated in 0.04505 seconds
