Home » Archived » BIRT » computed column has errors in preview
computed column has errors in preview [message #198772] Thu, 02 November 2006 14:49 Go to next message
Originally posted by: ndesai.applocation.net
I have a computed column called minutes. When I run the "preview results"
it all works perfectly. However, when I run the full preview of the
report, all of a sudden I get an error saying: The data type of computed
column "minutes" is java.lang.Integer, but one of its value is "null",
which cannot be converted to java.lang.Integer.
Anyone know how I can fix this?
Neesha
Re: computed column has errors in preview [message #199083 is a reply to message #198772] Fri, 03 November 2006 16:00 Go to previous messageGo to next message
Can you post the expression?
This is happening most likely becuase one of the fields is returning null.
You may want to put in your expression
if(row["mycol"]){
buildcomputed
}else{
0;
"Neesha" <ndesai@applocation.net> wrote in message
news:6c41140eba441a69cca4c43dd5d934f2$1@www.eclipse.org...
> Neesha
Re: computed column has errors in preview [message #199107 is a reply to message #199083] Fri, 03 November 2006 16:35 Go to previous messageGo to next message
Here's my computed column code:
if (row["details"].equalsIgnoreCase("STOP")) {
params["StopTime"] = row["reporttime"];
currentIsStart = false;
} else {
params["StartTime"] = row["reporttime"];
currentIsStart = true;
MinutesStopped = DateTimeSpan.seconds(params["StopTime"],
params["StartTime"]);
params["StartTime"] = "01/01/2006 00:00:00 AM";
MinutesStopped
And this is the code used to display it in the report:
<VALUE-OF>if (row["Minutes"] > 60) {
hours = Math.floor(row["Minutes"] / 60);
mins = row["Minutes"] % 60;
result = hours + " minutes " + mins + " seconds";
} else {
result = row["Minutes"] + " seconds";
result</VALUE-OF>
(Yeah, I know it looks funny, but it was originaly hours and minutes, and
then got changed to mins and seconds and I haven't gone through and
changed the variable names. :))
Neesha
> if(row["mycol"]){
> buildcomputed
> }else{
> 0;
>> Neesha
Re: computed column has errors in preview [message #199301 is a reply to message #199107] Mon, 06 November 2006 11:59 Go to previous messageGo to next message
You can do a check before you use the row values like
if ( row["details"] ){
This should remove the nulls.
Jason
news:5cda25f925be7831cf98a1df765c3c79$1@www.eclipse.org...
> } else {
> MinutesStopped
> } else {
> result</VALUE-OF>
> Neesha
>> null.
>> if(row["mycol"]){
>> buildcomputed
>> }else{
>> 0;
>>> Hi,
>>> results" it all works perfectly. However, when I run the full preview of
>>> the report, all of a sudden I get an error saying: The data type of
>>> computed column "minutes" is java.lang.Integer, but one of its value is
>>> "null", which cannot be converted to java.lang.Integer.
>>> Neesha
Re: computed column has errors in preview [message #199426 is a reply to message #199301] Mon, 06 November 2006 14:56 Go to previous messageGo to next message
So I changed my code to the following, and I still get the same problem
when I try to preview the report.
if (row["details"] != null) {
} else {
} else {
MinutesStopped = -2;
MinutesStopped
Neesha
> Jason
>> } else {
>> MinutesStopped
>> } else {
>> result</VALUE-OF>
>> Neesha
>>> null.
>>> if(row["mycol"]){
>>> buildcomputed
>>> }else{
>>> 0;
>>>> Hi,
>>>> Neesha
Re: computed column has errors in preview [message #199516 is a reply to message #199426] Mon, 06 November 2006 19:53 Go to previous messageGo to next message
Can you try
if (row["details"] ){
Also I would imagine the error is in something like
row["reporttime"];
So you may want to check it as well.
Jason
news:636df9d1ef9fbbd3832d9ac4cf037cff$1@www.eclipse.org...
> } else {
> } else {
> MinutesStopped
> Neesha
>> Jason
>>> } else {
>>> MinutesStopped
>>> } else {
>>> result</VALUE-OF>
>>> and then got changed to mins and seconds and I haven't gone through and
>>> Neesha
>>>> null.
>>>> if(row["mycol"]){
>>>> buildcomputed
>>>> }else{
>>>> 0;
>>>>> Hi,
>>>>> of the report, all of a sudden I get an error saying: The data type of
>>>>> is "null", which cannot be converted to java.lang.Integer.
>>>>> Neesha
Re: computed column has errors in preview [message #199715 is a reply to message #199516] Tue, 07 November 2006 12:44 Go to previous messageGo to next message
So I changed it to if (row["details"]) and it still didn't work. So then I
added in if (row["reporttime"]) and it still doesn't work. :(
Here's what my code looks like now.
if (row["details"]) {
if (row["reporttime"]) {
} else {
} else {
MinutesStopped = -3;
} else {
MinutesStopped
> Can you try
> row["reporttime"];
> Jason
>> } else {
>> } else {
>> MinutesStopped
>> Neesha
>>> Jason
>>>> } else {
>>>> MinutesStopped
>>>> } else {
>>>> result</VALUE-OF>
>>>> Neesha
>>>>> null.
>>>>> if(row["mycol"]){
>>>>> buildcomputed
>>>>> }else{
>>>>> 0;
>>>>>> Hi,
>>>>>> Neesha
Re: computed column has errors in preview [message #199738 is a reply to message #199715] Tue, 07 November 2006 13:54 Go to previous messageGo to next message
Remember that an expression returns a value and it is always the last
statement you run, so
make sure the last statement has a value. It looks like you are using
MinutesStopped. Can you initialize that to 1?
Can you post your report?
Jason
news:184b5a5d1d05d5d52ca8808d2cc1851b$1@www.eclipse.org...
> } else {
> } else {
> } else {
> MinutesStopped
>> Can you try
>> row["reporttime"];
>> Jason
>>> } else {
>>> } else {
>>> MinutesStopped
>>> Neesha
>>>> Jason
>>>>> } else {
>>>>> MinutesStopped
>>>>> } else {
>>>>> result</VALUE-OF>
>>>>> and changed the variable names. :))
>>>>> Neesha
>>>>>> null.
>>>>>> if(row["mycol"]){
>>>>>> buildcomputed
>>>>>> }else{
>>>>>> 0;
>>>>>>> Hi,
>>>>>>> preview of the report, all of a sudden I get an error saying: The
>>>>>>> data type of computed column "minutes" is java.lang.Integer, but one
>>>>>>> of its value is "null", which cannot be converted to
>>>>>>> java.lang.Integer.
>>>>>>> Neesha
Re: computed column has errors in preview [message #199762 is a reply to message #199738] Tue, 07 November 2006 17:51 Go to previous messageGo to next message
So I looked at it some more, and fiddled around and it still doesn't work.
I changed the expression I was using as I came up with a way better one
(easier to follow and actually works more in the way the last one was
intended to work).
Here it is:
MinutesStopped = -1;
if (row["details"] && row["reporttime"]) {
if (params["LastWasStop"] && row["details"].equalsIgnoreCase("START")) {
row["reporttime"]);
params["LastWasStop"] = false;
} else if (row["details"].equalsIgnoreCase("START")) {
} else {
params["LastWasStop"] = true;
MinutesStopped
I can't post the report, but I could email it to you if you could tell me
your email address.
Neesha
> Jason
>> } else {
>> } else {
>> } else {
>> MinutesStopped
>>> Can you try
>>> row["reporttime"];
>>> Jason
>>>> } else {
>>>> } else {
>>>> MinutesStopped
>>>> Neesha
>>>>> Jason
>>>>>> } else {
>>>>>> MinutesStopped
>>>>>> } else {
>>>>>> result</VALUE-OF>
>>>>>> Neesha
>>>>>>> null.
>>>>>>> if(row["mycol"]){
>>>>>>> buildcomputed
>>>>>>> }else{
>>>>>>> 0;
>>>>>>>> Hi,
>>>>>>>> java.lang.Integer.
>>>>>>>> Neesha
Re: computed column has errors in preview [message #199817 is a reply to message #199762] Wed, 08 November 2006 06:22 Go to previous messageGo to next message
Neesha,
This is a bug. Please see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163786.
Mingxia
news:a2381f68e81261568f4bafde11b79b9b$1@www.eclipse.org...
> intended to work).
> Here it is: MinutesStopped = -1;
> row["reporttime"]);
> } else { params["LastWasStop"] = true;
> MinutesStopped
> your email address.
> Neesha
>> Jason
>>> I added in if (row["reporttime"]) and it still doesn't work. :(
>>> } else {
>>> } else {
>>> } else {
>>> MinutesStopped
>>>> Can you try
>>>> row["reporttime"];
>>>> Jason
>>>>> problem when I try to preview the report.
>>>>> } else {
>>>>> } else {
>>>>> MinutesStopped
>>>>> Neesha
>>>>>> Jason
>>>>>>> } else {
>>>>>>> MinutesStopped
>>>>>>> } else {
>>>>>>> result</VALUE-OF>
>>>>>>> minutes, and then got changed to mins and seconds and I haven't gone
>>>>>>> through and changed the variable names. :))
>>>>>>> Neesha
>>>>>>>> returning null.
>>>>>>>> if(row["mycol"]){
>>>>>>>> buildcomputed
>>>>>>>> }else{
>>>>>>>> 0;
>>>>>>>>> Hi,
>>>>>>>>> one of its value is "null", which cannot be converted to
>>>>>>>>> java.lang.Integer.
>>>>>>>>> Neesha
Re: computed column has errors in preview [message #199897 is a reply to message #199817] Wed, 08 November 2006 17:25 Go to previous message
Hmm... I don't suppose there's anyway around this bug? Certain types of
things I need to leave out of the expression so it would work?
Neesha
mwu wrote:
> Neesha,
> Thanks
> Mingxia
>> intended to work).
>> row["reporttime"]);
>> MinutesStopped
>> your email address.
>> Neesha
>>> Jason
>>>> } else {
>>>> } else {
>>>> } else {
>>>> MinutesStopped
>>>>> Can you try
>>>>> row["reporttime"];
>>>>> Jason
>>>>>> } else {
>>>>>> } else {
>>>>>> MinutesStopped
>>>>>> Neesha
>>>>>>> Jason
>>>>>>>> } else {
>>>>>>>> MinutesStopped
>>>>>>>> } else {
>>>>>>>> result</VALUE-OF>
>>>>>>>> Neesha
>>>>>>>>> returning null.
>>>>>>>>> if(row["mycol"]){
>>>>>>>>> buildcomputed
>>>>>>>>> }else{
>>>>>>>>> 0;
>>>>>>>>>> Hi,
>>>>>>>>>> java.lang.Integer.
>>>>>>>>>> Neesha
Previous Topic:newsgroup for Jasper?
Next Topic:Adding a wiki page?
Current Time: Wed Oct 15 05:50:16 EDT 2025
Powered by FUDForum. Page generated in 0.09715 seconds
