| running editor programatically [message #198196] |
Wed, 07 March 2007 05:27  |
Originally posted by: raushansharma2004.yahoo.com
hi,
i want to know how to run an editor programmatically.
i have written editor in MyEditor class
i have created one toolbar button ,what i require is when this button
is pressed, the editor should be called.can someone give me its solution
| Re: running editor programatically [message #198248 is a reply to message #198196] |
Wed, 07 March 2007 07:46  |
Hi Raushan,
Inside the run method of an Action that you associate with your toolbar
button, use the following:
IWorkbenchWindow iWorkbenchWindow =
PlatformUI.getWorkbench().getActiveWorkbenchWindow();
IWorkbenchPage iWorkbenchPage = iWorkbenchWindow.getActivePage();
iWorkbenchPage.openEditor(myEditorInput, MyEditor.ID);
You will need to create a class that extends EditorInput.
Charlie
raushan wrote:
> hi, i want to know how to run an editor programmatically.
> button is pressed, the editor should be called.can someone give me its
> solution
FUDForum. Page generated in 0.08338 seconds
