Home » Modeling » GMF (Graphical Modeling Framework) » Launch GMF diagram validation from the edit popup menu
Launch GMF diagram validation from the edit popup menu [message #186069] Fri, 09 May 2008 10:24 Go to next message
i would like to launch the GMF diagram validation from the edit popup menu.
I think it is something like that:
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
class=" com.clearsy.eventb.model.diagram.providers.EventBValidationP rovider ">
<Priority name="Medium"/>
<popupContribution
id="org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContextMenu ">
<popupCustom
id="Validate Diagram">
</popupCustom>
</popupContribution>
</contributionItemProvider>
</extension>
But it doesn't work...
Can somebody help me please ?
Thanks.
Philippe
Re: Launch GMF diagram validation from the edit popup menu [message #186124 is a reply to message #186069] Fri, 09 May 2008 14:48 Go to previous messageGo to next message
Philippe,
You could try using the Eclipse org.eclipse.ui.popupMenus extension
point to contribute your action.
Linda
Philippe BLANC wrote:
> <extension
> <popupContribution
> <popupCustom
> </popupCustom>
> </extension>
> Thanks.
> Philippe
Re: Launch GMF diagram validation from the edit popup menu [message #186523 is a reply to message #186124] Tue, 13 May 2008 02:35 Go to previous message
Hi Linda,
Thank you for your answer.
The Eclipse org.eclipse.ui.popupMenus extension point needs a class with
a run action (a class implementing IObjectActionDelegate interface). My
class EventBValidationProvider doesn't implement it.
Do you know how I could perform validation (calling my class
EventBValidationProdiver) in my run method ?
Philippe
Linda Damus a écrit :
> Philippe,
> Linda
>> menu.
>> <extension
>> <popupContribution
>> <popupCustom
>> </popupCustom>
>> </extension>
>> Thanks.
>> Philippe
Previous Topic:Save As Exception
Next Topic:What's the matter with RenderedImageFactory.getInstance?
Current Time: Thu Nov 20 23:55:51 EST 2025
Powered by FUDForum. Page generated in 0.04187 seconds
