Home » Modeling » GMF (Graphical Modeling Framework) » NullPointerException for GraphicalEditPart.isSelectable
NullPointerException for GraphicalEditPart.isSelectable [message #182058] Thu, 10 April 2008 04:59 Go to next message
I am currently a newbie with GMF: I am working through the mindmap
tutorial, and the learn GMF in 15 minutes tutorial. (The 15 minutes
started three days ago, and I am approaching the 10 minute mark!). I am
generally very excited about the possibilities that GMF offers, and am
seriously considering using it as the primary graphical editor for a
commercial application.
I am at page two of the mindmap tutorial, having successfully had a
working diagram editor with simple topics linking to other topics. I have
got to the bit just before adding the link constraints. I have had
numerous issues to this point, but have managed to resolve them all.
Sadly when I run the diagram editor at the moment, I have a problem. When
I add a topic, link to other topics, everything is fine. When I add a
thread, the yellow sticky appears, but no matter what I do (for example
just clicking on the background, dragging a topic...) I get
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.isSelectable(GraphicalEditPart.java:1257)
org.eclipse.gmf.runtime.diagram.ui.editparts.CompartmentEdit Part.isSelectable(CompartmentEditPart.java:58)
org.eclipse.gmf.runtime.diagram.ui.internal.tools.Rubberband SelectionTool.calculateNewSelection(RubberbandSelectionTool. java:116)
org.eclipse.gmf.runtime.diagram.ui.internal.tools.Rubberband SelectionTool.performMarqueeSelect(RubberbandSelectionTool.j ava:397)
org.eclipse.gmf.runtime.diagram.ui.internal.tools.Rubberband SelectionTool.handleButtonUp(RubberbandSelectionTool.java:33 1)
I suspect it is a modelling issue: I have tried hard to exactly follow the
instructions but somewhere I will have a broken link.
I would appreciate advice on both what the problem is, and also on how to
troubleshoot it. At the moment the only approach I can think of is to
download the source code and start debugging.
I attach my gmfgen file, which I beleive should contain enough information
to recreate the problem.
Thanks very much for the help
Phil RIce
<gmfgen:GenEditorGenerator xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:gmfgen="http://www.eclipse.org/gmf/2006/GenModel">
<diagram
visualID="79"
editPartClassName="MapEditPart"
itemSemanticEditPolicyClassName="MapItemSemanticEditPolicy"
notationViewFactoryClassName="MapViewFactory"
canonicalEditPolicyClassName="MapCanonicalEditPolicy"
iconProviderPriority="Low"
validationProviderPriority="Low">
<diagramRunTimeClass
href=" ../../../plugin/org.eclipse.gmf.runtime.notation/model/notat ion.genmodel#//notation/Diagram "/>
<elementType
xsi:type="gmfgen:MetamodelType"
editHelperClassName="MapEditHelper"/>
<viewmap
xsi:type="gmfgen:FigureViewmap"
figureQualifiedClassName="org.eclipse.draw2d.FreeformLayer"/ >
<domainDiagramElement
href="Mindmap.genmodel#//mindmap/Map"/>
<childNodes
visualID="2001"
editPartClassName="ThreadEditPart"
itemSemanticEditPolicyClassName="ThreadItemSemanticEditPolicy "
notationViewFactoryClassName="ThreadViewFactory"
canonicalEditPolicyClassName="ThreadCanonicalEditPolicy"
compartments="//@diagram/@compartments.1"
graphicalNodeEditPolicyClassName="ThreadGraphicalNodeEditPolicy "
createCommandClassName="ThreadCreateCommand"
containers="//@diagram/@compartments.0">
href=" ../../../plugin/org.eclipse.gmf.runtime.notation/model/notat ion.genmodel#//notation/Node "/>
<elementType
editHelperClassName="ThreadEditHelper"/>
<viewmap
xsi:type="gmfgen:InnerClassViewmap"
layoutType="TOOLBAR_LAYOUT"
className="StickyNoteFigure"
classBody="&#xA;/**&#xA; * @generated&#xA; */&#xA;public class
StickyNoteFigure extends org.eclipse.draw2d.RectangleFigure
{&#xA;&#xA;&#xA;&#x9;/**&#xA;&#x9; * @generated&#xA;&#x9;
*/&#xA;&#x9;private org.eclipse.draw2d.RectangleFigure
fFigureStickyNoteFigure; &#xA;&#x9;/**&#xA;&#x9; * @generated&#xA;&#x9;
*/&#xA;&#x9;private org.eclipse.draw2d.RectangleFigure fFigureThreadItems;
*/&#xA;&#x9;public StickyNoteFigure()
{&#xA;&#x9;&#x9;&#xA;&#xA;&#x9;org.e clipse.draw2d.ToolbarLayout layoutThis
= new
org.eclipse.draw2d.ToolbarLayout();&#xA;&#x9;layoutT his.setStretchMinorAxis(true);&#xA;&#x9;layoutThis.s etMinorAlignment(org.eclipse.draw2d.ToolbarLayout.ALIGN_CENT ER&#xA;);&#xA;&#xA;&#x9;layoutThis.setSpacin g(0);&#xA;&#x9;layoutThis.setVertical(true);&#xA ;&#xA;&#x9;this.setLayoutManager(layoutThis);&#x A;&#xA;&#x9;&#x9;&#x9;this.setBackgroundColo r(THIS_BACK&#xA;);&#xA;&#x9;&#x9;createConte nts();&#xA;&#x9;}&#xA;&#x9;/**&#xA;& #x9;
* @generated&#xA;&#x9; */&#xA;&#x9;private void
createContents(){&#xA;&#xA;&#xA;org.eclipse.gmf. runtime.draw2d.ui.figures.WrapLabel
stickyNoteNameFigure0 = new
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel();&# xA;stickyNoteNameFigure0.setText(&quot;&lt;Sticky > &quot;);&#xA;&#xA;this.add(stickyNoteNameFigure0 );&#xA;&#xA;&#xA;&#xA;fFigureThreadItems
= new
org.eclipse.draw2d.RectangleFigure();&#xA;&#xA;this. add(fFigureThreadItems);&#xA;&#xA;fFigureThreadItems .setLayoutManager(new
org.eclipse.draw2d.StackLayout());&#xA;&#xA;&#xA ;&#x9;}&#xA;&#xA;&#xA;&#xA;&#xA;& ;#x9;/**&#xA;&#x9;
* @generated&#xA;&#x9; */&#xA;&#x9;private boolean myUseLocalCoordinates =
false;&#xA;&#xA;&#x9;/**&#xA;&#x9; * @generated&#xA;&#x9;
*/&#xA;&#x9;protected boolean useLocalCoordinates() {&#xA;&#x9;&#x9;return
myUseLocalCoordinates;&#xA;&#x9;}&#xA;&#xA;& amp;#x9;/**&#xA;&#x9; *
@generated&#xA;&#x9; */&#xA;&#x9;protected void
setUseLocalCoordinates(boolean useLocalCoordinates)
{&#xA;&#x9;&#x9;myUseLocalCoordinates =
useLocalCoordinates;&#xA;&#x9;}&#xA;&#xA;&am p;#xA;&#xA;&#x9;/**&#xA;&#x9; *
@generated&#xA;&#x9; */&#xA;&#x9;public org.eclipse.draw2d.RectangleFigure
getFigureStickyNoteFigure() {&#xA;&#x9;&#x9;return
fFigureStickyNoteFigure;&#xA;&#x9;}&#xA;&#x9 ;/**&#xA;&#x9; *
getFigureThreadItems() {&#xA;&#x9;&#x9;return
fFigureThreadItems;&#xA;&#x9;}&#xA;&#xA;& ;#xA;}&#xA;&#xA;/**&#xA; *
@generated&#xA; */&#xA;static final org.eclipse.swt.graphics.Color
THIS_BACK = new org.eclipse.swt.graphics.Color(null, 250, 250,
190);&#xA;&#xA;">
<attributes
xsi:type="gmfgen:StyleAttributes"
fixedBackground="true"/>
<requiredPluginIDs>org.eclipse.draw2d</requiredPluginIDs>
<requiredPluginIDs>org.eclipse.gmf.runtime.draw2d.ui</requiredPluginIDs >
</viewmap>
<modelFacet>
<metaClass
href="Mindmap.genmodel#//mindmap/Thread"/>
<containmentMetaFeature
href="Mindmap.genmodel#//mindmap/Topic/comments"/>
<childMetaFeature
</modelFacet>
<labels
visualID="4002"
editPartClassName="ThreadSubjectEditPart"
itemSemanticEditPolicyClassName="ThreadSubjectItemSemanticEditPolicy "
notationViewFactoryClassName="ThreadSubjectViewFactory"
elementIcon="true">
<viewmap
xsi:type="gmfgen:ParentAssignedViewmap"
getterName="getFigureStickyNoteFigure"
figureQualifiedClassName="org.eclipse.draw2d.RectangleFigure ">
<attributes
</viewmap>
<modelFacet
xsi:type="gmfgen:FeatureLabelModelFacet"
editPattern="">
<metaFeatures
href="Mindmap.genmodel#//mindmap/Thread/subject"/>
</modelFacet>
</labels>
</childNodes>
<childNodes
visualID="2002"
editPartClassName="ThreadItemEditPart"
itemSemanticEditPolicyClassName="ThreadItemItemSemanticEditPolicy "
notationViewFactoryClassName="ThreadItemViewFactory"
canonicalEditPolicyClassName="ThreadItemCanonicalEditPolicy "
graphicalNodeEditPolicyClassName="ThreadItemGraphicalNodeEditPolicy "
createCommandClassName="ThreadItemCreateCommand"
containers="//@diagram/@compartments.1">
<elementType
editHelperClassName="ThreadItemEditHelper"/>
<viewmap
= new
= new
190);&#xA;&#xA;">
<attributes
</viewmap>
<modelFacet>
<metaClass
href="Mindmap.genmodel#//mindmap/ThreadItem"/>
href="Mindmap.genmodel#//mindmap/Thread/items"/>
<childMetaFeature
</modelFacet>
<labels
visualID="4001"
editPartClassName="ThreadItemBodyEditPart"
itemSemanticEditPolicyClassName="ThreadItemBodyItemSemanticEditPolicy "
notationViewFactoryClassName="ThreadItemBodyViewFactory"
elementIcon="true">
<viewmap
<attributes
</viewmap>
<modelFacet
xsi:type="gmfgen:FeatureLabelModelFacet">
<metaFeatures
href="Mindmap.genmodel#//mindmap/ThreadItem/body"/>
</modelFacet>
</labels>
</childNodes>
<topLevelNodes
visualID="1001"
editPartClassName="TopicEditPart"
itemSemanticEditPolicyClassName="TopicItemSemanticEditPolicy "
notationViewFactoryClassName="TopicViewFactory"
canonicalEditPolicyClassName="TopicCanonicalEditPolicy"
compartments="//@diagram/@compartments.0"
graphicalNodeEditPolicyClassName="TopicGraphicalNodeEditPolicy "
createCommandClassName="TopicCreateCommand">
<elementType
editHelperClassName="TopicEditHelper"/>
<viewmap
className="RoundedTopicFigure"
RoundedTopicFigure extends org.eclipse.draw2d.RoundedRectangle
*/&#xA;&#x9;private org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel
fFigureTopicNameFigure; &#xA;&#xA;&#xA;&#x9;/**&#xA;&#x9; *
@generated&#xA;&#x9; */&#xA;&#x9;public RoundedTopicFigure()
{&#xA;&#x9;&#x9;&#x9;&#x9;this.setCorner Dimensions(new
org.eclipse.draw2d.geometry.Dimension(getMapMode().DPtoLP(12 )&#xA;,
getMapMode().DPtoLP(12)&#xA;));&#xA;&#x9;this.se tForegroundColor(THIS_FORE&#xA;);&#xA;&#x9;& #x9;createContents();&#xA;&#x9;}&#xA;&#x9;/* *&#xA;&#x9;
createContents(){&#xA;&#xA;&#xA;fFigureTopicName Figure = new
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel();&# xA;fFigureTopicNameFigure.setText(&quot;&quot;);& ;#xA;&#xA;this.add(fFigureTopicNameFigure);&#xA;& ;#xA;&#xA;&#x9;}&#xA;&#xA;&#xA;&#xA; &#xA;&#x9;/**&#xA;&#x9;
getFigureTopicNameFigure() {&#xA;&#x9;&#x9;return
fFigureTopicNameFigure;&#xA;&#x9;}&#xA;&#xA; &#xA;}&#xA;&#xA;/**&#xA; *
THIS_FORE = new org.eclipse.swt.graphics.Color(null, 220, 220,
250);&#xA;&#xA;">
<attributes
fixedForeground="true"/>
</viewmap>
<modelFacet>
<metaClass
href="Mindmap.genmodel#//mindmap/Topic"/>
href="Mindmap.genmodel#//mindmap/Map/rootTopics"/>
<childMetaFeature
</modelFacet>
<labels
visualID="4003"
editPartClassName="TopicNameEditPart"
itemSemanticEditPolicyClassName="TopicNameItemSemanticEditPolicy "
notationViewFactoryClassName="TopicNameViewFactory"
elementIcon="true">
<viewmap
getterName="getFigureTopicNameFigure"
figureQualifiedClassName="org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel "/>
<modelFacet
<metaFeatures
href="Mindmap.genmodel#//mindmap/Topic/name"/>
</modelFacet>
</labels>
</topLevelNodes>
<links
visualID="3001"
editPartClassName="TopicSubtopicsEditPart"
itemSemanticEditPolicyClassName="TopicSubtopicsItemSemanticEditPolicy "
notationViewFactoryClassName="TopicSubtopicsViewFactory"
createCommandClassName="TopicSubtopicsCreateCommand"
reorientCommandClassName="TopicSubtopicsReorientCommand">
href=" ../../../plugin/org.eclipse.gmf.runtime.notation/model/notat ion.genmodel#//notation/Edge "/>
<elementType
xsi:type="gmfgen:SpecializationType"/>
<viewmap
className="TopicSubtopicsFigure"
TopicSubtopicsFigure extends
org.eclipse.gmf.runtime.draw2d.ui.figures.PolylineConnection Ex
{&#xA;&#xA;&#xA;&#xA;&#xA;&#x9;/**&a mp;#xA;&#x9; * @generated&#xA;&#x9;
*/&#xA;&#x9;public TopicSubtopicsFigure()
{&#xA;&#x9;&#x9;&#xA;&#x9;&#x9;setTa rgetDecoration(createTargetDecoration());&#xA;&#x9;} &#xA;&#xA;&#x9;/**&#xA;&#x9;
org.eclipse.draw2d.RotatableDecoration createTargetDecoration()
{&#xA;&#x9;&#x9;org.eclipse.draw2d.PolylineDecor ation df = new
org.eclipse.draw2d.PolylineDecoration();&#xA;&#x9;&a mp;#x9;return
df;&#xA;&#x9;}&#xA;&#xA;&#xA;&#xA;&a mp;#xA;}&#xA;&#xA; ">
</viewmap>
<modelFacet
xsi:type="gmfgen:FeatureLinkModelFacet">
<metaFeature
href="Mindmap.genmodel#//mindmap/Topic/subtopics"/>
</modelFacet>
</links>
<compartments
visualID="5001"
editPartClassName="TopicThreadCompartmentEditPart"
itemSemanticEditPolicyClassName="TopicThreadCompartmentItemSemanticEditPolicy "
notationViewFactoryClassName="TopicThreadCompartmentViewFactory "
canonicalEditPolicyClassName="TopicThreadCompartmentCanonicalEditPolicy "
childNodes="//@diagram/@childNodes.0"
title="Thread Compartment"
needsTitle="false"
node="//@diagram/@topLevelNodes.0"
listLayout="false">
<viewmap
250);&#xA;&#xA;">
<attributes
</viewmap>
</compartments>
<compartments
visualID="5002"
editPartClassName="ThreadThreadItemCompartmentEditPart"
itemSemanticEditPolicyClassName="ThreadThreadItemCompartmentItemSemanticEditPolicy "
notationViewFactoryClassName="ThreadThreadItemCompartmentViewFactory "
canonicalEditPolicyClassName="ThreadThreadItemCompartmentCanonicalEditPolicy "
childNodes="//@diagram/@childNodes.1"
title="ThreadItemCompartment"
canCollapse="false"
needsTitle="false"
node="//@diagram/@childNodes.0">
<viewmap
= new
= new
190);&#xA;&#xA;">
<attributes
</viewmap>
</compartments>
<palette>
<groups
title="mindmap">
<entries
xsi:type="gmfgen:ToolEntry"
title="Map"
description="Create new Map"/>
<entries
title="Relationship tool"
description="Create new Relationship"
genLinks="//@diagram/@links.0"/>
<entries
title="Topic tool"
description="Create new Topic"
genNodes="//@diagram/@topLevelNodes.0"/>
<entries
title="Thread"
genNodes="//@diagram/@childNodes.0"/>
<entries
title="Thread Item"
genNodes="//@diagram/@childNodes.1"/>
</groups>
</palette>
<preferencePages
xsi:type="gmfgen:GenStandardPreferencePage"
iD="com.erudine.newGmf.diagram.general"
name="Mindmap Diagram">
<children
iD="com.erudine.newGmf.diagram.appearance"
name="Appearance"
kind="Appearance"/>
<children
iD="com.erudine.newGmf.diagram.connections"
name="Connections"
kind="Connections"/>
<children
iD="com.erudine.newGmf.diagram.printing"
name="Printing"
kind="Printing"/>
<children
iD="com.erudine.newGmf.diagram.rulersAndGrid"
name="Rulers And Grid"
kind="RulersAndGrid"/>
<children
iD="com.erudine.newGmf.diagram.pathmaps"
name="Pathmaps"
kind="Pathmaps"/>
</preferencePages>
</diagram>
<plugin/>
<editor/>
<navigator>
<childReferences
child="//@diagram"/>
<childReferences
parent="//@diagram/@childNodes.0"
child="//@diagram/@childNodes.1"/>
<childReferences
parent="//@diagram/@topLevelNodes.0"
child="//@diagram/@childNodes.0"/>
<childReferences
parent="//@diagram"
child="//@diagram/@topLevelNodes.0"/>
<childReferences
parent="//@diagram"
child="//@diagram/@links.0"
groupName="links"
groupIcon="icons/linksNavigatorGroup.gif"/>
<childReferences
parent="//@diagram/@links.0"
referenceType="out_target"
groupName="target"
groupIcon="icons/linkTargetNavigatorGroup.gif"/>
<childReferences
referenceType="in_source"
groupName="incoming links"
groupIcon="icons/incomingLinksNavigatorGroup.gif"/>
<childReferences
groupName="source"
groupIcon="icons/linkSourceNavigatorGroup.gif"/>
<childReferences
groupName="outgoing links"
groupIcon="icons/outgoingLinksNavigatorGroup.gif"/>
</navigator>
<diagramUpdater/>
<propertySheet>
<tabs
xsi:type="gmfgen:GenStandardPropertyTab"
iD="appearance"/>
<tabs
iD="diagram"/>
<tabs
xsi:type="gmfgen:GenCustomPropertyTab"
iD="domain"
label="Core">
<filter
xsi:type="gmfgen:TypeTabFilter">
<types>org.eclipse.gmf.runtime.notation.View</types>
<types>org.eclipse.gef.EditPart</types>
<generatedTypes>abstractNavigatorItem</generatedTypes>
</filter>
</tabs>
</propertySheet>
<domainGenModel
href="Mindmap.genmodel#/"/>
</gmfgen:GenEditorGenerator>
Re: NullPointerException for GraphicalEditPart.isSelectable [message #182134 is a reply to message #182058] Thu, 10 April 2008 07:43 Go to previous message
Have you compared your solution against the one provided in CVS?
- Rich
On 4/10/08 4:59 AM, in article
cfc15ec353dd976140bfd51319012045$1@www.eclipse.org, "Phil Rice"
> java.lang.NullPointerException
> at
> at
> at
> ulateNewSelection(RubberbandSelectionTool.java:116)
> at
> ormMarqueeSelect(RubberbandSelectionTool.java:397)
> at
> leButtonUp(RubberbandSelectionTool.java:331)
> Phil RIce
> xmlns:xmi="http://www.omg.org/XMI"
> <diagram
> visualID="79"
> #//notation/Diagram"/>
> <elementType
> <viewmap
> <childNodes
> visualID="2001"
> #//notation/Node"/>
> <elementType
> <viewmap
> = new
> ue);&#xA;&#x9;layoutThis.setMinorAlignment(org.eclip se.draw2d.ToolbarLayout.AL
> IGN_CENTER&#xA;);&#xA;&#xA;&#x9;layoutThis.s etSpacing(0);&#xA;&#x9;layoutThis.
> setVertical(true);&#xA;&#xA;&#x9;this.setLayoutM anager(layoutThis);&#xA;&#xA;&
> #x9;&#x9;&#x9;this.setBackgroundColor(THIS_BACK& #xA;);&#xA;&#x9;&#x9;createCon
> tents();&#xA;&#x9;}&#xA;&#x9;/**&#xA;&am p;#x9;
> Label
> e0.setText(&quot;&lt;Sticky> &quot;);&#xA;&#xA;this.add(stickyNoteNameFigure0 );
> = new
> xA;&#xA;fFigureThreadItems.setLayoutManager(new
> 190);&#xA;&#xA;">
> <attributes
> </viewmap>
> <modelFacet>
> <metaClass
> <childMetaFeature
> </modelFacet>
> <labels
> visualID="4002"
> elementIcon="true">
> #//notation/Node"/>
> <viewmap
> <attributes
> </viewmap>
> <modelFacet
> editPattern="">
> <metaFeatures
> </modelFacet>
> </labels>
> </childNodes>
> <childNodes
> visualID="2002"
> #//notation/Node"/>
> <elementType
> <viewmap
> = new
> Label
> = new
> 190);&#xA;&#xA;">
> <attributes
> </viewmap>
> <modelFacet>
> <metaClass
> <childMetaFeature
> </modelFacet>
> <labels
> visualID="4001"
> elementIcon="true">
> #//notation/Node"/>
> <viewmap
> <attributes
> </viewmap>
> <modelFacet
> <metaFeatures
> </modelFacet>
> </labels>
> </childNodes>
> <topLevelNodes
> visualID="1001"
> #//notation/Node"/>
> <elementType
> <viewmap
> ;);&#xA;&#x9;&#x9;createContents();&#xA;& ;#x9;}&#xA;&#x9;/**&#xA;&#x9;
> ure.setText(&quot;&quot;);&#xA;&#xA;this.add (fFigureTopicNameFigure);&#xA;&#xA
> ;&#xA;&#x9;}&#xA;&#xA;&#xA;&#xA;& ;#xA;&#x9;/**&#xA;&#x9;
> 250);&#xA;&#xA;">
> <attributes
> </viewmap>
> <modelFacet>
> <metaClass
> <childMetaFeature
> </modelFacet>
> <labels
> visualID="4003"
> elementIcon="true">
> #//notation/Node"/>
> <viewmap
> <modelFacet
> <metaFeatures
> </modelFacet>
> </labels>
> </topLevelNodes>
> <links
> visualID="3001"
> #//notation/Edge"/>
> <elementType
> <viewmap
> #xA;&#x9;}&#xA;&#xA;&#x9;/**&#xA;&#x 9;
> </viewmap>
> <modelFacet
> <metaFeature
> </modelFacet>
> </links>
> <compartments
> visualID="5001"
> needsTitle="false"
> listLayout="false">
> #//notation/Node"/>
> <viewmap
> 250);&#xA;&#xA;">
> <attributes
> </viewmap>
> </compartments>
> <compartments
> visualID="5002"
> licy"
> canCollapse="false"
> needsTitle="false"
> #//notation/Node"/>
> <viewmap
> = new
> Label
> = new
> 190);&#xA;&#xA;">
> <attributes
> </viewmap>
> </compartments>
> <palette>
> <groups
> title="mindmap">
> <entries
> title="Map"
> <entries
> <entries
> title="Topic tool"
> <entries
> title="Thread"
> <entries
> title="Thread Item"
> </groups>
> </palette>
> <preferencePages
> <children
> name="Appearance"
> kind="Appearance"/>
> <children
> name="Connections"
> <children
> name="Printing"
> kind="Printing"/>
> <children
> <children
> name="Pathmaps"
> kind="Pathmaps"/>
> </preferencePages>
> </diagram>
> <plugin/>
> <editor/>
> <navigator>
> <childReferences
> <childReferences
> <childReferences
> <childReferences
> parent="//@diagram"
> <childReferences
> parent="//@diagram"
> groupName="links"
> <childReferences
> groupName="target"
> <childReferences
> <childReferences
> groupName="source"
> <childReferences
> </navigator>
> <diagramUpdater/>
> <propertySheet>
> <tabs
> iD="appearance"/>
> <tabs
> iD="diagram"/>
> <tabs
> iD="domain"
> label="Core">
> <filter
> </filter>
> </tabs>
> </propertySheet>
> <domainGenModel
Previous Topic:How can I show the contents of a node by double clicking it
Next Topic:How to realize drag and drop with outline TreeEditPart?
Current Time: Thu Oct 23 14:14:13 EDT 2025
Powered by FUDForum. Page generated in 0.57159 seconds
