| Setting up a project from scratch. [message #16988] |
Tue, 25 January 2005 23:23 |
Originally posted by: yogurtemperor.hotmail.com
I had to reformat yesterday and my project settings for Eclipse (version
2.1.3, build ID 200403101828) were lost.
I am trying to get my old DoJa 1.5 project working again but I keep
getting the following errors:
Unbound classpath variable: 'DOJA_CLASSES/lib/classes.zip'.
Unbound classpath variable: 'DOJA_CLASSES/lib/doja_classes.zip'.
These files are in C:\iDK\lib\classes.zip and C:\iDK\lib\doja_classes.zip
respectively.
I have gone to Properties/Java Build Path/Libraries and found two
green/blue orbs, one labelled DOJA_CLASSES/lib/classes.zip and the other
DOJA_CLASSES/lib/doja_classes.zip.
I created a variable to point to each file and then attached each variable
to the Source attachment to each of these orbs.
It did nothing.
I then Add Library... to creat a new library with each of the correct
zip files. Failed again.
So what do I need to be doing?
L. Spiro
FUDForum. Page generated in 0.24713 seconds
