Home » Language IDEs » Java Development Tools (JDT) » External CVS Resync Issue
External CVS Resync Issue [message #176502] Fri, 03 September 2004 18:07 Go to next message
Command line CVS changes are not reflected in the CVS view of Eclipse in
general. Also noticed that changes made through external editors are not
reflected in Eclipse in some cases. If you change Java files Eclipse at
least prompts you but if you have some external editor (e.g., using vim for
xml files) Eclipse does not show that it has changed until you execute an
update.
Re: External CVS Resync Issue [message #176647 is a reply to message #176502] Mon, 06 September 2004 04:15 Go to previous message
Please file bug reports for each of these cases.
Dani
>update.
Previous Topic:Difference between debug-time and run-time when writing plug-ins...
Next Topic:Original receiver parameter name while moving a non-static method
Current Time: Sat Nov 08 21:21:21 EST 2025
Powered by FUDForum. Page generated in 0.03791 seconds
