Home » Language IDEs » C / C++ IDE (CDT) » auto-correction for cdt enviroment
auto-correction for cdt enviroment [message #176027] Mon, 04 September 2006 11:01 Go to next message
Originally posted by: alessio.lai.infobusiness.it
Hi everyone !
Is there a mode to enable autocorrection for the cdt enviroment ?
For autocorrection I mean the procedure of autocompiling continuosly a
source
code in a separated thread to see the error of the code before doing the
compile action .
Best regards .
Alessio
Re: auto-correction for cdt enviroment [message #176035 is a reply to message #176027] Mon, 04 September 2006 11:37 Go to previous messageGo to next message
Originally posted by: msuhk45.gmail.com
I think it's not posstible with C++ because you have to disable "Build
Automatically"
see this
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/cdt- home/user/faq.html?cvsroot=Tools_Project#create
Re: auto-correction for cdt enviroment [message #176092 is a reply to message #176035] Tue, 05 September 2006 08:44 Go to previous message
Alessio,
the closest you can get is in fact to enable "Build Automatically" which
will start off a build every time you save a file. It works nicely for real
small applications but becomes cumbersome for bigger projects. Hence the
recommendation to turn it off, as mus correctly pointed out.
Norbert
Previous Topic:getting target image (executable) name
Next Topic:How to increase content assist scope
Current Time: Fri Oct 17 23:29:50 EDT 2025
Powered by FUDForum. Page generated in 0.04409 seconds
