| Connection Profiles [message #16329] |
Fri, 09 June 2006 10:53  |
i would like to use the created Connection Profiles in my Plugin.
How can I retrieve all Connection Profiles ?
Oliver
| Re: Connection Profiles [message #16355 is a reply to message #16342] |
Fri, 09 June 2006 13:57  |
Hi Rob,
great, that is what I am looking for.
Oliver
Rob Cernich schrieb:
> Oliver,
> Have a look at org.eclipse.datatools.connectivity.ProfileManager. The
> methods you should look at are:
> getProfiles() - returns all the profile defined in the workspace.
> getProfilesByCategory() - returns all the profiles contained by the
> specified category (not sure if this recurses through subcategories).
> getProfileByName() - returns a profile with the specified name.
> getProfileByInstanceID() - returns the profile with the specified ID.
> getProfileByProviderID() - returns all the profiles of a specific type
> (e.g. using
> org.eclipse.datatools.connectivity.db.derby.embedded.connect ionProfile
> would return all the Derby connection profiles;
> org.eclipse.datatools.connectivity.db.generic.connectionProf ile would
> return all the generic DB connection profiles).
> Hope that helps.
> Sincerely,
> Rob Cernich
| Re: Connection Profiles [message #579399 is a reply to message #16329] |
Fri, 09 June 2006 13:55  |
Oliver,
(e.g. using
Hope that helps.
Sincerely,
Rob Cernich
| Re: Connection Profiles [message #579419 is a reply to message #16342] |
Hi Rob,
Oliver
> Oliver,
> (e.g. using
> Hope that helps.
> Sincerely,
> Rob Cernich
FUDForum. Page generated in 0.03856 seconds
