Home » Language IDEs » C / C++ IDE (CDT) » Debug Error: mi_cmd_stack_list_frames: No stack
Debug Error: mi_cmd_stack_list_frames: No stack [message #171462] Wed, 14 June 2006 19:43 Go to next message
Originally posted by: eclipse.dharty.com
I'm trying to debug a process which I can run fine. I'm getting the
error shown in the Subject. To debug my inability to debug, I created a
simple hello world app and tried to debug it. It runs fine.
When I debug the executable (gnu on windows) I get a popoup saying that
"Execution is Susupended because of an Error" with the following Details:
"You can't do that without a process to debug."
The console outputs the following:
mi_cmd_stack_list_frames: No stack.
Warning: /src/java/CDTTest/.settings;C: No such file or directory.
Warning: /src/java/CDTTest;C: No such file or directory.
Warning: /c/src/java/CDTTest/C: No such file or directory.
This is very similar to the output I get in my "real" application. I'm
not sure why all the file/directories are being post-fixed with "C:"
Any thoughts?
Re: Debug Error: mi_cmd_stack_list_frames: No stack [message #171466 is a reply to message #171462] Thu, 15 June 2006 02:59 Go to previous messageGo to next message
I had similar problem before, application runs fine, but debugger
complains with the same error as you have. Solution was to delete
project files and recreate them again. I am not sure if there is some
other (better) solution, but this worked for me.
Marko
Re: Debug Error: mi_cmd_stack_list_frames: No stack [message #171476 is a reply to message #171466] Thu, 15 June 2006 13:36 Go to previous messageGo to next message
Well, I didn't think that would work, but I tried it anyway.
I had created a test project just to test the problem, and the new
project had the problem from the get go. I did as you suggested, but
when I recreated the project files, the error still occurs.
Thanks though.
Anyone else?
>> a simple hello world app and tried to debug it. It runs fine.
>> that "Execution is Susupended because of an Error" with the following
>> Details:
> Hello,
> Marko
Re: Debug Error: mi_cmd_stack_list_frames: No stack [message #171631 is a reply to message #171476] Mon, 19 June 2006 16:14 Go to previous message
Solution:
Add the cygwin path to the global windows environment, or set it in a
batch file which then launches eclipse eg:
set PATH=c:\usr\cygwin\bin;%PATH%
start C:\usr\eclipse-3.1.2\eclipse.exe
> Thanks though.
> Anyone else?
>>> created a simple hello world app and tried to debug it. It runs fine.
>>> Details:
>> Hello,
>> Marko
Previous Topic:Show QString in Debug
Next Topic:how do i configure an external library?
Current Time: Thu Oct 23 08:07:51 EDT 2025
Powered by FUDForum. Page generated in 0.03511 seconds
