Home » Language IDEs » ServerTools (WTP) » WTP 1.0 to 1.5 API/extension points migration guide
WTP 1.0 to 1.5 API/extension points migration guide [message #167894] Fri, 28 April 2006 13:40 Go to next message
Anyone know of a WTP 1.0 to 1.5 API/extension points migration guide ?
I'm currently struggling with porting from 1.0 XML handling to WTP 1.5.
I get no warning nor compile errors; but nothing is working ;(
So I have the feeling some extension point has changed name or behavior
so any tips appreciated ;)
/max
Re: WTP 1.0 to 1.5 API/extension points migration guide [message #168014 is a reply to message #167894] Sat, 29 April 2006 10:47 Go to previous messageGo to next message
so, I figured it out and it is *very* suttle!
I had the following before (worked in everything pre-1.5)
<content-type
base-type="org.eclipse.core.runtime.xml"
file-extensions="xml"
id="content-type.hbm.xml"
name="Hibernate Mapping Content-Type"
priority="normal">
id's can apparently not contain dot's (I remember some other issue with
the core platform regarding this)
so the following works:
<content-type
id="hbmxmlsource"
priority="normal">
Can anyone tell me why ? And if it is so, why doesn't something complain
hard when a content-type id contains dot's ?
/max
> /max
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: WTP 1.0 to 1.5 API/extension points migration guide [message #168053 is a reply to message #167894] Sat, 29 April 2006 23:13 Go to previous messageGo to next message
On Fri, 28 Apr 2006 13:40:52 -0400, Max Rydahl Andersen
Max, there shouldn't be that much (famous last words :) but there are some
things
known issues listed in
http://wiki.eclipse.org/index.php/New_Help_for_Old_Friends
Let us know if we've forgotten something in that document, or if you have
other questions
on migration.
(To mention an "obvious" one, that may not be so obvious to eveyong ...
1.5 does require Eclipse 3.2,
one of the latest RC's would be good.)
HTH
Re: WTP 1.0 to 1.5 API/extension points migration guide [message #168123 is a reply to message #168014] Sun, 30 April 2006 13:01 Go to previous messageGo to next message
On Sat, 29 Apr 2006 10:47:33 -0400, Max Rydahl Andersen
Max, I don't think its just content type IDs, it should be true for any
extension ID.
For details, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=128866
Funny thing is ... this was the whole reason for the 'a' part of 3.2M5a.
And ... as part of the "workaround" was that the new namespace naming rules
should have an effect only if you update your plugin to say
<?eclipse version="3.2"?>
That is, ID's with dot's should still work if the PI at top of eclipse
plugin
still says <?eclipse version="3.2"?>
(And, BTW, the platform team would say the rule of "no dot's in ID names"
is not not new ... just a new
enforcement of them :)
So, if you did not use 3.2 in PI, that might be worth opening a new bug
related to bug 128866.
If you did use 3.2, then you were not only breaking original syntax rules
on IDs, but you
even asked for the new enforcement of them :)
Re: WTP 1.0 to 1.5 API/extension points migration guide [message #168179 is a reply to message #168123] Mon, 01 May 2006 10:05 Go to previous messageGo to next message
>> complain hard when a content-type id contains dot's ?
> extension ID.
That is the bug thingy I remembered.
> rules
I did not update any plugin.xml to 3.2.
> plugin
> names" is not not new ... just a new
Which i'm quite fine with; but they could be good sports and make the PDE
editor warn about them ;)
> rules on IDs, but you
blah ;)
i'll open a bug.
Re: WTP 1.0 to 1.5 API/extension points migration guide [message #168193 is a reply to message #168179] Mon, 01 May 2006 10:18 Go to previous message
> blah ;)
> i'll open a bug.
For the record:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139491
Previous Topic:WTP Install/Update on Custom Eclipse Application
Next Topic:roject .JETEmitters is missing required library...
Current Time: Mon Nov 03 14:37:24 EST 2025
Powered by FUDForum. Page generated in 0.03436 seconds
