Home » Language IDEs » Java Development Tools (JDT) » Javadoc formatter ignores "clear blank lines=false" between xdoclet tags
Javadoc formatter ignores "clear blank lines=false" between xdoclet tags [message #165592] Wed, 23 June 2004 08:52 Go to next message
I'm using xdoclet tags in my classes.
In the previous M builds the code formatter didn't touch these lines:
* [text]
* @ejb.interface-method
* @ejb.persistence
* @ejb.pk-field
* @ejb.value-object match="deviceLight"
* @jboss.persistence auto-increment="true"
But the RC2 and 3 after using the formatter 2 times the comment looks:
* [text unchanged]
* @ejb.interface-method @ejb.persistence @ejb.pk-field
Each tag with no additional parameters moved up to one line. This is not
nice if your code has a lot of xdoclet tags and the code generation
fails because xdoclet cant find it's tags. I had to disable comment
formatting to work with rc3.
Should this be reported to bugzilla or will this be fixed in the final
release?
Thanks.
regards,
Marcel
Re: Javadoc formatter ignores "clear blank lines=false" between xdoclet tags [message #165600 is a reply to message #165592] Wed, 23 June 2004 11:51 Go to previous messageGo to next message
Originally posted by: newsserver_mails.bodden.de
> release?
Best do a search on Bugzilla and if you cannot find it, put it up.
Eric
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
GPG: BB465582
Re: Javadoc formatter ignores "clear blank lines=false" between xdoclet tags [message #167646 is a reply to message #165600] Thu, 08 July 2004 07:32 Go to previous message
"Eric Bodden" <newsserver_mails@bodden.de> wrote in message
news:cbc8ui$f03$1@eclipse.org...
> > release?
Here's the bug you're looking for:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=68577
Previous Topic:HOW DO I ? : sharing/overriding default preferences between users in 3.0
Next Topic:roadmap
Current Time: Thu Oct 02 16:29:57 EDT 2025
Powered by FUDForum. Page generated in 0.07910 seconds
