Home » Eclipse Projects » Eclipse 4 » LoginDialog in LifeCycleManager
Re: LoginDialog in LifeCycleManager [message #1097487 is a reply to message #1097339] |
Thu, 29 August 2013 20:03 |
Arjan Huijzer Messages: 9 Registered: October 2011 |
Junior Member |
Hello Eric,
Thanks for your help!
I tried injecting the MApplication into the LifeCycleManager class:
public class LifeCycleManager {
@Inject
MApplication application;
@PostContextCreate
public void postContextCreate(IEclipseContext context) {
final Shell shell = new Shell(SWT.TOOL | SWT.NO_TRIM);
LoginDialog dialog = new LoginDialog(shell);
if (dialog.open() != Window.OK) {
// close the application
System.exit(-1);
However, this results in an error:
org.eclipse.e4.core.di.InjectionException: Unable to process "LifeCycleManager.application": no actual value was found for the argument "MApplication".
Next, I tried injecting it in my LoginDialog class, but all I get is a null value.
public class LoginDialog extends TitleAreaDialog {
// Widgets
private Text textUsername;
private Text textPassword;
@Inject
public LoginDialog(Shell parent) {
super(parent);
protected Control createContents(Composite parent) {
Control contents = super.createContents(parent);
setTitle("Credentials");
setMessage("Please provide the credentials.");
return contents;
protected Control createDialogArea(Composite parent) {
Composite area = (Composite) super.createDialogArea(parent);
System.out.println(application);
Composite container = new Composite(area, SWT.NULL);
container.setLayout(new GridLayout(2, false));
container.setLayoutData(new GridData(GridData.FILL_BOTH));
new Label(container, SWT.NULL).setText("Username");
textUsername = new Text(container, SWT.BORDER);
textUsername.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
new Label(container, SWT.NULL).setText("Password");
textPassword = new Text(container, SWT.PASSWORD | SWT.BORDER);
textPassword.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
return area;
protected Point getInitialSize() {
return new Point(500, 300);
Any idea what I am missing?
Arjan
[Updated on: Thu, 29 August 2013 20:04] Report message to a moderator
Re: LoginDialog in LifeCycleManager [message #1097523 is a reply to message #1097487] |
Thu, 29 August 2013 21:10 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Nothing - the model has not been loaded at this point you need to use
another point in time e.g. @ProcessAddons
Tom
On 29.08.13 22:03, Arjan Huijzer wrote:
> Hello Eric,
> @Inject
> @PostContextCreate
> System.exit(-1);
> null value.
> // Widgets
> @Inject
> public CredentialsDialog(Shell parent) {
> super(parent);
> @Override
> return contents;
> @Override
> return area;
> @Override
> Arjan
Re: LoginDialog in LifeCycleManager [message #1097737 is a reply to message #1097523] |
Fri, 30 August 2013 05:22 |
Junior Member |
Hello Tom,
Thanks for your help. I am one step closer, but I still have not got it working......
I now use @ProcessAdditions in my LIfeCycleManager. Furthermore, I used ContextInjectionFactory to inject the context into the login dialog.
@ProcessAdditions
public void processAdditions(IEclipseContext context) {
ContextInjectionFactory.inject(dialog, context);
System.exit(-1);
In the LoginDialog the state is persisted in the following method:
protected void okPressed() {
application.getPersistedState().put(CREDENTIALS_USERNAME, textUsername.getText());
super.okPressed();
When I run the application, the state seems to be persisted after I close it. My workbench.xmi file has the following entry:
<persistedState key="credentials.username" value="Arjan"/>
However, when I start the application again, the code to read the persisted state in the login dialog does not seem to work:
String persistedUsername = application.getPersistedState().get(CREDENTIALS_USERNAME);
persistedUsername is NULL
Note: I did remove the clearPersistedState property from the plugin.xml.
Arjan
Re: LoginDialog in LifeCycleManager [message #1098167 is a reply to message #1097737] |
Fri, 30 August 2013 18:18 |
Most likely you launch with -clearPersistedState
Tom
On 30.08.13 07:22, Arjan Huijzer wrote:
> Hello Tom,
> working......
> @ProcessAdditions
> System.exit(-1);
> @Override
> super.okPressed();
> persistedUsername is NULL :(
> Arjan
Re: LoginDialog in LifeCycleManager [message #1706133 is a reply to message #1098239] |
Mon, 24 August 2015 05:12 |
But friend I am try to check login validation and false time focus login screen and correct to open application, how and where i'm apply code and i am post my code also....
Login Dialog
import javax.inject.Inject;
import org.eclipse.e4.ui.model.application.MApplication;
import org.eclipse.jface.dialogs.TitleAreaDialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
// Widgets
public static Text textUsername;
public static Text textPassword;
@Inject
// @Inject
// EMenuService menuService;
* @wbp.parser.constructor
public LoginDialog() {
super(null);
@Inject
public LoginDialog(Shell parentShell) {
super(parentShell);
setTitle("Login");
setMessage("Please provide credentials");
return contents;
checkLoginValidation(textUsername.getText(),textPassword.getText());
return area;
private void checkLoginValidation(String text, String text2) {
Lifecycle manager class
package secdemo;
import org.eclipse.e4.core.contexts.ContextInjectionFactory;
import org.eclipse.e4.core.contexts.IEclipseContext;
import org.eclipse.e4.core.services.events.IEventBroker;
import org.eclipse.e4.ui.di.UIEventTopic;
import org.eclipse.e4.ui.workbench.UIEvents;
import org.eclipse.e4.ui.workbench.lifecycle.PostContextCreate;
import org.eclipse.e4.ui.workbench.lifecycle.PreSave;
import org.eclipse.e4.ui.workbench.lifecycle.ProcessAdditions;
import org.eclipse.e4.ui.workbench.lifecycle.ProcessRemovals;
import org.eclipse.equinox.app.IApplicationContext;
import org.eclipse.jface.window.Window;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.widgets.Monitor;
import org.eclipse.e4.core.di.annotations.Optional;
import org.osgi.service.event.Event;
import org.osgi.service.event.EventHandler;
import login.LoginDialog;
@SuppressWarnings("restriction")
public class Manager {
@PostContextCreate
void postContextCreate(IEclipseContext workbenchContext) {
@PreSave
void preSave(IEclipseContext workbenchContext) {
@ProcessAdditions
void processAdditions(final IEclipseContext workbenchContext, IEventBroker eventBroker) {
LoginDialog dialog = ContextInjectionFactory.make(LoginDialog.class, workbenchContext);
if(dialog.open() != Window.OK){
// close application
System.exit(-1);
eventBroker.subscribe(UIEvents.UILifeCycle.APP_STARTUP_COMPLETE, new EventHandler() {
// @Override
public void handleEvent(Event event) {
// if(LoginDialog.textUsername.getText().equals("123") && LoginDialog.textPassword.getText().equals("123") ){
appStartupComplete(workbenchContext);
// continue to the initial window
@ProcessRemovals
void processRemovals(IEclipseContext workbenchContext) {
@Optional
public void applicationStartupComplete(@UIEventTopic(UIEvents.UILifeCycle.APP_STARTUP_COMPLETE) Event event)
private void appStartupComplete(IEclipseContext workbenchContext) {
@PostContextCreate
void postContextCreate(IApplicationContext appContext, Display display) {
final Shell shell = new Shell(SWT.LEFT);
// close the static splash screen
appContext.applicationRunning();
// position the shell
setLocation(display, shell);
System.exit(-1);
private void setLocation(Display display, Shell shell) {
Monitor monitor = display.getPrimaryMonitor();
Rectangle monitorRect = monitor.getBounds();
Rectangle shellRect = shell.getBounds();
int x = monitorRect.x + (monitorRect.width - shellRect.width) / 2;
int y = monitorRect.y + (monitorRect.height - shellRect.height) / 2;
shell.setLocation(x, y);
apply plugin.xml file in lifecycleURI....
Pleas help me friend .....
Lalit
Current Time: Fri Mar 29 09:24:32 GMT 2024
Powered by FUDForum. Page generated in 0.01778 seconds
