Home » Language IDEs » C / C++ IDE (CDT) » indexer : jvm has not enough memory
indexer : jvm has not enough memory [message #164197] Tue, 21 February 2006 11:11 Go to next message
I have a workspace with five C++ eclipse projetcs under clearcase plugin.
I have built my 5 projects inside eclipse. When the indexer has to work, it
takes more than 15 minutes to finish its work, and the jvm takes more than
1500 Mo ( I have limited it at the lauch). I can not reach all the
declarations by F3.
My context : eclipse 3.1 cdt 3.0.1 jvm 1.4.2_10sun, plugin clearcase, under
Linux Red Hat WS 3.0
Could you help me.
Thanks.
Eric
Re: indexer : jvm has not enough memory [message #164209 is a reply to message #164197] Tue, 21 February 2006 11:31 Go to previous messageGo to next message
Originally posted by: berend.chalmers.se
Dear Eric,
Have you tried upgrading to java version 1.5.x? This has solved many
problems for me running eclipse under linux.
Berend.
> Hello,
> declarations by F3.
> Could you help me.
> Thanks.
> Eric
Re: indexer : jvm has not enough memory [message #164290 is a reply to message #164209] Wed, 22 February 2006 11:54 Go to previous messageGo to next message
It's not better with jvm 1.5.
Eric
"Berend van Wachem" <berend@chalmers.se> a
Re: indexer : jvm has not enough memory [message #164431 is a reply to message #164290] Fri, 24 February 2006 05:22 Go to previous messageGo to next message
Originally posted by: arne.anka.ginguppin.de
try switching the indexer from full to ctags.
On Wed, 22 Feb 2006 17:54:22 +0100, Eric Celerse
> Eric
> "Berend van Wachem" <berend@chalmers.se> a écrit dans le message de
> news:dtff8n$s11$2@utils.eclipse.org...
>> Dear Eric,
>> Berend.
>> > Hello,
> plugin.
>> work,
> it
> than
>> > declarations by F3.
> under
>> > Could you help me.
>> > Thanks.
>> > Eric
Re: indexer : jvm has not enough memory [message #164454 is a reply to message #164431] Fri, 24 February 2006 05:26 Go to previous messageGo to next message
what are the differences ?
"arne anka" <arne.anka@ginguppin.de> a
Re: indexer : jvm has not enough memory [message #164469 is a reply to message #164454] Fri, 24 February 2006 05:37 Go to previous messageGo to next message
On Fri, 24 Feb 2006 11:26:23 +0100, Eric Celerse
don't really know ;-) but it solved my out-of-memory-issue.
> "arne anka" <arne.anka@ginguppin.de> a écrit dans le message de
> news:op.s5g23tj0uyrgnr@localhost.localdomain...
>> > Eric
>> >> Dear Eric,
>> >> Berend.
>> >> > Hello,
>> > plugin.
>> >> work,
>> > it
>> more
>> > than
>> >> > declarations by F3.
>> clearcase,
>> > under
>> >> > Could you help me.
>> >> > Thanks.
>> >> > Eric
Re: indexer : jvm has not enough memory [message #165246 is a reply to message #164469] Mon, 06 March 2006 05:03 Go to previous messageGo to next message
I have no results at all with that option
Re: indexer : jvm has not enough memory [message #165263 is a reply to message #165246] Mon, 06 March 2006 08:11 Go to previous message
don't know whether it helps but have you considered to update to cdt 3.0.2?
according to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=122494
"ctags is the right answer for now,"
regards
On Mon, 06 Mar 2006 11:03:11 +0100, Eric Celerse
> news:op.s5g3s2ceuyrgnr@localhost.localdomain...
>> >> > Eric
>> >> >> Dear Eric,
>> many
>> >> >> Berend.
>> >> >> > Hello,
>> clearcase
>> >> > plugin.
>> to
>> >> >> work,
>> >> > it
>> >> more
>> >> > than
> the
>> >> >> > declarations by F3.
>> >> clearcase,
>> >> > under
>> >> >> > Could you help me.
>> >> >> > Thanks.
>> >> >> > Eric
Previous Topic:Adding Include Paths from Workspace
Next Topic:c++ console
Current Time: Sat Jul 19 18:10:25 EDT 2025
Powered by FUDForum. Page generated in 0.04917 seconds
